cossy won't start ???
i've just fitted a engine into a 3 door shell i bought and can't get it started
also fitted a 2wd saph engine loom, group a fuel pump.
i've got power to the fuel pump and had a plug into number 1 lead and it had a spark.
what things can i check???
yeah i believe so. as you look at the dizzy cap when its fitted the bottom right is no1 them top right is no 3, top left is 4 bottom left is 2
thats correct is'nt it??
ecu is plugged in
there is'nt a switch in a 3 door for the pump is there??
using a lever 6 ecu
everything was out of my saph that was running before i removed it.
I've just had another look and it still won't start.
what i've found out is the fuel lines were the wrong way round ( was getting dark, lol).
i've change the crank sensor with a 4x4 one i had. what's the gap supposed to be for the crank sensor?? it's 0.4mm at the minute
there is plenty of pressure to the fuel reg now
there is a good spark to the plugs but they are dry when i've removed them after i've tried to start it. so i don't think the injectors are working???
what could that be??
i've fitted the engine from a 2wd saph
How long have the injectors been stood ?
Petrol leaves a gooey residue when it dries out and this is a common causes of injectors sticking...... I always run the injectors through a cleaning cycle on the machine before i store them...
yes they are. i think its a fuel problem because the plugs should have been wet if it was a spark problem.
what does the crank sensor control?
what controls the injectors?
only been about 7 weeks car was running before i removed everything
Also check the phase sensor as well as the crank sensor, are the phase and crank sensors plugged into the correct plugs ?.......it`s an easy mistake to make when reconnecting the loom
i will check the plugs mate thanks. phase sensor should be ok as a1 rallysport just set it up
i've just had another look. i've got the crank sensor at 1mm now and check the crank sensor and phase sensor plugs in case they are the wrong way round but they are colour coded white and black.
i've took the injectors out the manifold but kept them in the rail, i turned it over and there is'nt much petrol flowing out. just spitting little bit.
any one know someone in the north east that can have a look??
i think it's a fuel problem.
there's pressure before the regulator but it's not filling the rail up. i've tried a few different regulators and it still won't fill up.
how do they work???
the petrol feed does go to the bottom of the regulator and no direct to the fuel rail?
how do they work???
how do they work???
how do they work???
No mate, the pump feeds the rail directly via the fuel filter and the regulator controls the flow back to the tank out the bottom of it .
Does the pump run ?
I had the same on my twin turbo xr4x4 when i replaced the fuel lines. The guy that had a look for me pulled the fuel line off the reg and got covered in fuel!
Is this the return of HAJ?
glad to here you have got it running now we had the say with my 3dr but the way we solved it i pulled number 1 plug out put a small bit of fuel down the hole put the plug in hit the key and it cothed so we swopped the lines round and she came into life
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
