cams for gt30 turbo
Old Oct 21, 2008 | 09:00 AM
coachworz's Avatar
coachworz
Default cams for gt30 turbo
what cam choice is good for gt30 turbo anyone?
Old Oct 21, 2008 | 09:04 AM
AJC's Avatar
AJC
i have 16 inlet 14 exhaust
Old Oct 21, 2008 | 09:08 AM
coachworz's Avatar
coachworz
what kind of responds and power?
Old Oct 21, 2008 | 09:36 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
GT3071 or 3076?
What power are you hoping for?
Old Oct 21, 2008 | 11:33 AM
coachworz's Avatar
coachworz
only know its gt30 with .63 housing ... close to 500 maybe
Old Oct 21, 2008 | 11:34 AM
Chip's Avatar
Chip
The 3076 and the 3071 are very different animals, so worth finding out which you have (similar difference really to a T4 and a T34 or a T34 and a T3)
Old Oct 21, 2008 | 02:42 PM
coachworz's Avatar
coachworz
was told its good for about slightly over 500 plus hp.
Old Oct 21, 2008 | 03:04 PM
Chip's Avatar
Chip
Probably a GT3076 then.
Do you have headwork?
I suspect you will find it surges without.
Old Oct 22, 2008 | 07:08 AM
coachworz's Avatar
coachworz
its a gt3076 with .60 yes head is ported and engine is balanced with tubular manifold and swedish plenum. with 1000cc injectors
Old Oct 22, 2008 | 07:10 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
BD14 inlet and standard exhaust. Is it going on a standard head and does the turbo have a ported shroud?
Old Oct 22, 2008 | 10:45 AM
coachworz's Avatar
coachworz
head is ported and polish... sorry dun understand ported shroud
Old Oct 22, 2008 | 11:14 AM
Chip's Avatar
Chip
Ported shroud is a modification on the turbo to help reduce surge.
As per what Rich said, a BD14 inlet and a standard exhaust will be good at that level.
Old Oct 22, 2008 | 01:54 PM
coachworz's Avatar
coachworz
std 2wd exhaust cam?
JK12
33
Apr 26, 2021 12:09 PM
robnock
21
May 13, 2019 05:29 PM
Rsmat
63
Sep 25, 2015 12:11 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
