ignition pinking???
Old Oct 17, 2008 | 10:05 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default ignition pinking???
as above, ill rev the s2 hold it on 2k and you can here it like snappin hard to explain,
Old Oct 17, 2008 | 10:29 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
with no load sure it aint the 2k death rattle?
Old Oct 18, 2008 | 01:23 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
nah is defo pinkin, i have a misfre problem on high boost, think my cam is fucked
Old Oct 18, 2008 | 06:39 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Dizzy slipped?
Old Oct 18, 2008 | 09:10 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
how can i sort the dizzy? can i do it on my own, or a tuner job?
Old Oct 18, 2008 | 10:57 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Go look at it first... if its slipped it should be fairly obvious (you'll see the imprint of where it was sitting before most likely)..
You should check it with a timing light though..........
Another thing.. Make sure the vacuum line from the plenum to the ECU isn't squashed/blocked anywhere...
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
