Calibrating a TPS???
Old Oct 17, 2008 | 07:17 PM
Miller 3's Avatar
Miller 3
First off everything was fine' Then i notice on my engine monitor that the throttle angle was saying 15% with no throttle applied? pulled the TPS off but still plugged in and still says 15%... Tried to turn it to 0% but it will not go any lower ... Was idling at 2K this morning but that has since gone back to normal. Put on a brand new TPS but its still the same ..
Please help
Old Oct 17, 2008 | 07:28 PM
Miller 3's Avatar
Miller 3
Default Calibrating a TPS???
Double post
Old Oct 17, 2008 | 08:05 PM
Miller 3's Avatar
Miller 3
Up
Old Oct 17, 2008 | 08:50 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
weird that you cant adjust it back to zero....
Old Oct 17, 2008 | 08:57 PM
Miller 3's Avatar
Miller 3
Thats what i thought' surely if its plugged in but away from the TB it should read 0% yes?
Old Oct 17, 2008 | 09:27 PM
Miller 3's Avatar
Miller 3
Anyone?
Old Oct 17, 2008 | 09:32 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Try to adjust the stop on the back of the throttlebody, it may have come loose, loosen it a bit, adjust the tps again until sero, then u may have to adjust the idling screw again
Old Oct 17, 2008 | 09:46 PM
Miller 3's Avatar
Miller 3
But shouldn't it read 0% as it is plugged in to a TPS that is not attached to the TB?
Old Oct 17, 2008 | 10:17 PM
Miller 3's Avatar
Miller 3
Can any body help me
Old Oct 17, 2008 | 10:21 PM
cossiemanden
ahh, yes it should be, but not always as it´s up the the chip what data from the tps is input.
otherwise it may be a defect wire?
Does it wary in data if u open the throttle slowly or is it stabel?
Old Oct 17, 2008 | 10:26 PM
Miller 3's Avatar
Miller 3
It dose move up but not sure if it goes to 100%. I did check the voltage on one of the wires today and it was just under 5v at WOT and 3.2 at 1/2 and iirc 0.4 at rest
Old Oct 17, 2008 | 10:52 PM
ECU Monitor Enthusiast
Have a check of the wiring loom condition.
Also, check the monitor is connected properly.
Sometimes due to bad installation the wire pulls the plug out ofthe back of the monitor and causes missreads.
Old Oct 17, 2008 | 11:04 PM
Miller 3's Avatar
Miller 3
Thanks Si hope its that' Already bought a new TPS .
PS i have a ryan loom and all looks well
Old Oct 18, 2008 | 06:39 AM
They can be adjusted internally if not set correctly at the factory as there is a allen screw inside that is the stop that the mechanism rest on, the stop/allen key is adjustable once halves are prised apart, but shouldn't imagne it's this tbh.
Old Oct 20, 2008 | 06:33 PM
Miller 3's Avatar
Miller 3
Well i still have this problem and the plug at the back of the SECS is fine... Do they go wrong at all?
What pins at the ECU would i have to check and in what combination? ie volts/continuity ?
Old Oct 20, 2008 | 06:35 PM
WHat makes you think you have a problem ?
Does the car idle ok and accelerate smoothly ?
Old Oct 20, 2008 | 06:37 PM
Miller 3's Avatar
Miller 3
The engine monitor just went to 15% one morning Si and when i unplug the TPS it only goes to 85ish% ?
Old Oct 20, 2008 | 07:42 PM
Miller 3's Avatar
Miller 3
Just found this' Dose it sound about right for setting up a PF09 without the monitor ?
Pin 1 of ecu connect your negative probe.
Pin 17 of ecu connect your positive probe.
Plug the ecu multiplug back into the ecu and turn on the ignition.
Adjust the sensor to read <0.35volts at idle position.
Old Oct 20, 2008 | 08:52 PM
YEs thats about right.
The best way that ALWAYS works for me is to unplug the TPS and loosen the retaining screws to a point where the TPS sits where it wants to under its own spring pressure.
Then tighten the screws and reconnect it.
On a L6 (2wd) system, the voltage should sit around 4.7 volts or more at idle and go down to about 0.3 volts at full throttle.
On a L8/P8 (4wd) system, the voltage should sit around 0.3 volts at idle and go up to about 4.6 volts at full throttle.
If the car is running right idling and acceration wise, The chances are the monitor has a fault or the wiring to it is faulty.
Old Oct 20, 2008 | 10:55 PM
Miller 3's Avatar
Miller 3
Can the monitor be repaird and how long would it take Si
Old Oct 21, 2008 | 12:51 PM
Miller 3's Avatar
Miller 3
Just checked the volts and they are 0.34v closed and 4.70 WOT so i presume the monitor is out of sink
Old Oct 21, 2008 | 07:03 PM
Ok, Give Mike Rainbird a PM, he may be able to sort out a repair.
If not, PM me and I will give you a number of a man who can .
Old Oct 21, 2008 | 07:14 PM
Miller 3's Avatar
Miller 3
Briliant' Thanks for your help Simon
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Roosie
Aug 15, 2015 08:09 PM
