Subaru Starting Problem
Old Oct 8, 2008 | 11:28 AM
JK99's Avatar
JK99
Default Subaru Starting Problem
I appreciate this is not the best forum to ask about this but i got next to nothing fromt he guys on Scoobynet and thought I'd try the helpful lot on here:
It's a problem when starting the car from cold or if it's been sitting for 10mins+. It takes ages to fire for some reason.
I've checked the history and a Crank sensor was replaced a couple of years back for the same symptoms and cured it.
The problems is, i've had a new Cam and Crank sensor tried on the car. Fuel pump is next up as it seems to take an age to prime.
It never fails to start, just sick of being embarrassed when I try to start it front of anyone after I left it off for 10mins+.
Forgot to add, I've also replaced the Coolant Temp sensor, MAF and O2 sensor with no joy. And if I switch it off for less than 10mins, it fires no problem?
I'm puzzled! HELP!
JK
Old Oct 8, 2008 | 02:15 PM
I would check the rail pressure by hooking a gauge and see exactly how long it takes to prime, and the fuel pressure is correct as well, to start with.
When was the fuel filter last changed ?
Old Oct 8, 2008 | 08:58 PM
Azrael's Avatar
Azrael
Which model year is it?
I would look at the pump as well.
Old Oct 9, 2008 | 11:40 AM
JK99's Avatar
JK99
Sorry, I forgot to mention that its a 1998 STi Type R (V4).
Fuel pressure was 36psi according to the gauge. I've now removed the adjustable reg and it's back on a standard Subaru one (partly to rule out any issues).
It's going in for a new Fuel Pump next Thursday and i'll throw on a fuel filter aswell in the mean-time.
Thanks for your help guys, it's been pissin me off for ages and it's the only thing that's been ruining what is brilliant car.
JK
Old Oct 9, 2008 | 11:50 AM
Azrael's Avatar
Azrael
If you have adjustable regulator, do you have any other modifications?
Old Oct 9, 2008 | 12:01 PM
JK99's Avatar
JK99
Yes mate, but nothing serious just a de-catted exhuast and panel filter.
The guy who tunes them up here suspects the fuel pump or wiring after we put the fuelling back to standard (i.e standard regulator etc).
Old Oct 9, 2008 | 12:07 PM
Azrael's Avatar
Azrael
Fuel pump is very common. Buy walbro 255l it's almost straight swap (there are two types, one is OK for older Subarus), basically 30 minutes job if you never done it.
Old Oct 9, 2008 | 06:14 PM
JK99's Avatar
JK99
Thanks for that. It's a Walbro that's going in the car. I hope that's the end of my issues.
Will update the thread when it's done.
JK
Old Oct 10, 2008 | 07:15 PM
Aaroncast's Avatar
Aaroncast
give it back to the hairdresser!!!!!!!!!!!!!!!!!!!!!!
Old Oct 27, 2008 | 07:11 PM
JK99's Avatar
JK99
Very funny Aaroncast - what do you drive??
Azrael - I've had the fuel pump done and basically gone over everything on the car. Any little things that weren't looking 100% have been sorted or replaced. All sensors are spot-on yet the the car still struggles.
Options left are - ECU or weeping injector as it reeks of fuel sometimes but doesn't give out any black smoke.
I spoke to the old owner and it was also like this before the engine went pop and he replaced it.
Leaves me to think it's the ECU - Apexi time?
JK
Old Oct 27, 2008 | 08:58 PM
tommy6206's Avatar
tommy6206
Do a ecu reset black & green plugs under steering colom and check for fault code when the light flashes
Old Oct 28, 2008 | 10:16 AM
spoilt_rs's Avatar
spoilt_rs
My saph had a similar fault when it was overfuelling, it would coke up the plugs, then it would have trouble starting. You did mention that you could smell fuel, so you could also have an overfuelling issue causing the same problem??
Old Oct 28, 2008 | 12:37 PM
JK99's Avatar
JK99
It was on the Select monitor and the ECU was reset afterwards to see if anything else came up.
It's got to be the ECU i'm thinking now, especially if it was like this before the engine went too. I was thinking it could've been wiring if it was only after the engine was re-fitted.
JK
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
