more gasket probs!
Old Sep 25, 2008 | 08:49 PM
105epwr's Avatar
105epwr
Smile more gasket probs!
is there a gasket after the exhaust manifold to the turbo elbow on a 2wd manifold.(the twin bore pipe between turbo and ex manifold)cheers
Old Sep 25, 2008 | 08:51 PM
Mark Shead's Avatar
Mark Shead
No
Mark
Old Sep 25, 2008 | 08:54 PM
J1mbo's Avatar
J1mbo
B1mbo
no and dont use any sealer nothin
Old Sep 25, 2008 | 09:06 PM
105epwr's Avatar
105epwr
just that ive brought this cossie and the engine was fucked the bloke who had it b4 siliconed every gasket on the engine,spun no4 shell,ground no 4 rod to fit shells,put a -18 actuator on so only 12psi of boost,low oil pressure so that fucked the turbo it goes on and on-so who no"s what will be mising etc!so im just going through the process of getting it built back together properly now,re ground crank,new rods etc
oh and the bloke worked for the AA aswell!
Old Sep 26, 2008 | 05:54 AM
Think I might be joining the RAC now then!!
As said no gasket they soon soot up and seal, very occasionally they may be warped and need a slight skim if not sealing properly.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 23, 2015 06:28 AM
