Boost gauge hookup
Old Sep 13, 2008 | 11:09 PM
thebronze's Avatar
thebronze
Blag Master
Default Boost gauge hookup
I bought an Autometer Boost gauge for My XR4Ti and am trying to figure out where the best place to hook up the boost/vacuum line... Need help asap and a pic would be great
Old Sep 14, 2008 | 12:18 AM
Blackbid_Leys_1991's Avatar
Blackbid_Leys_1991
The Chunk Of Funk
We don't get many XR4Ti's here in the UK, so you might struggle getting a picture. As far as the best way to hook up the boost/vacuum line is concerned, the most common place is the plenum chamber. If your engine management system uses a MAP sensor, you could just tap into it's pressure feed line.
Dean
Old Sep 14, 2008 | 10:37 AM
NATH-RSZT's Avatar
NATH-RSZT
Dean
I would'nt plumb a boost gauge in off my map sensor line, i have a single solid tube for my map sensor on its own so it gets a proper vac/boost signal.
Just anywere on the inlet manifold for the boost gauge find another vacum hose to put a t piece in.
Not the brake servo hose thow.
Old Sep 14, 2008 | 12:15 PM
Blackbid_Leys_1991
The Chunk Of Funk
Had a quick look on the internet this morning and found this...
Inside the green square is your plenum and the smaller of the two pipes in the orange square, looks like a vacuum/boost feed which you tap your gauge into.
Dean
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
