abs removal on a erst
Old Sep 2, 2008 | 03:30 PM
mark2's Avatar
mark2
Default abs removal on a erst
hi peeps
is this the right way to remove the abs from a series 2
1) remove pumps
2) change fluid res to a xr3 coz of return pipes from pumps
3)2 new pipes from the 2 outlets from master cylinder ,one to each t piece/distributor to front and back brakes on the inner wings
also can i reuse the the nuts/joiners to do this but use new pipe and flare it to fit
any help would be grateful
mark2
Old Sep 3, 2008 | 08:15 PM
Simmo's Avatar
Simmo
It's a long time since I done it on my old one but that's the gist of it yes (although some just loop the reservoir returns together with a short piece of hose).
You want to reuse the male/female unions?... they're dirt cheap from most motor factors so may as well replace as well (they get pretty rusty after 18yrs or so!!!)
Old Sep 6, 2008 | 11:07 AM
mark2's Avatar
mark2
cheers fella will renew male and female connections as its a good point stated
mark
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
