Zetec Turbo Project Breaking
I've decide to stop my project to buy a saff coz everything is for sale if you want any photos please ask and i will email them or post on this thread for you.
thanks for looking.
Large front mount intercooler (twin pass)3" inlet and outlet comes with silicon 90deg bend 3"- 52mm (new) sold
2.0l zetec block just machined and honed for pistons. inc main caps and crank front breather blocked turbo oil drain and new rear breather pipe fitted sold
4 supertech forged low comp pistons (new) SOLD
4 Eagle H section steel rods(new) SOLD
new main and big end shells(standard size)(new) SOLD
1.8 zetec sump and strainer(used)
silver top cam cover(used)
Black top cam cover(used)
2.0l zetec head with cams(standard 2.0l) tapped and drilled to take erst manifold(used)
Kent cam pullies(not great condition but still will work) blue(used) SOLD
meagsquirt 2 ecu loom and disk set up to run edis4(new) SOLD
edis 4 module and plug and coil pack(used) SOLD
19 row earls oil cooler(used) SOLD
Mocal oil cooler adapor plate with thermostate(new) SOLD
custom made zetec turbo in let with massive 76mm throttle body and rover turbo injectors SOLD
universal adjustable fuel pressure regulator with gauge(used once) SOLD
universal oil breather(new) SOLD
T0E4 turbo with 360 degree thrust bearing with T3 flange good for 45psi (new) SOLD
comes with used oil drain pipe and used braided oil feed pipe
Tial Copy External waste gate(38mm) come with flanges to make your own screamer pipe(new)
Erst exhauste manifold(used) SOLD
Cosworth Pipercross cone filter(used but excellent condition) SOLD
Focus rs clutch(new) SOLD
Zetec 240mm flywheel just be re faced
All my 4x4 stuff to make a car 4x4 using mondeo escort parts inc gear box transfere box rear diff escort diff hanger mondeo diff hanger escort fuel tank and pumps rear drive shafts the important front drivers side drive shaftmondeo prop mondeo rear hubs with spacers to take escort shocks.
I'm also breaking a fiesta turbo all still avalible but no engine, gear box or managment.
I'm sure there is more i will list when i remember.
Please feel free to pm for prices or make me a sensible offer.
I will post anything you want as long as you are willing to pay the postage or you are more than welcome to pick it up or arrange your own couriour..
I'll do my best to answere any qustions you may have,
Thanks for looking,
Phil
thanks for looking.
Thanks for looking,
Phil
Hi phil,
would you have a supressor for an ofab fiesta turbo loom? If so how much? also do you have any pics of the oil breather and how much do you want for it. pm me if you like.
Si
Si
