rear wheel bearings? help
Old Aug 7, 2008 | 07:43 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default rear wheel bearings? help
if the wheel bearings are fucked will it make my steerin wheel shake? had balence done and still shaking?
Old Aug 8, 2008 | 07:23 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
depends on how fucked!
Old Aug 8, 2008 | 07:30 PM
rst in breaking's Avatar
rst in breaking
have you felt for play in the wheel? at what speed does it vibrate?
Old Aug 8, 2008 | 09:37 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
it vibrates from about 50 to 90 then after 90 t aint that bad, i thought tie rod ends but i doubt
Old Aug 8, 2008 | 09:38 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i can move the drum side to side a quite a bit on both sides is this normal?
malkiemac3579
Jul 14, 2017 12:10 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
muz
Aug 1, 2015 06:48 AM
