clutch cable
its on the ap racing web site use the mk5 escort pedal which is adjustable and the quadrent which you cut a bit out of it
Escort Clutch Pedal Modifications
Ř220mm Clutch Fitment to Ford Escort range 1986 onwards.
![](http://www.apracing.com/pics/productpics/epm004.jpg)
To improve clutch release on Ford Escorts, post 1995 models are fitted with an adjustable clutch pedal and improved (white) quadrant as standard (see photo's).
When fitting CP3560-1, CP3560-2 cover assemblies or the clutch kits CP2000-8, CP2015-8 & CP2000-35 , AP Racing recommends that the adjustable pedal, improved quadrant and a new clutch cable are fitted to optimize clutch release in light of the higher release loads.
The latest Mk5 Escort Quadrant (white) has an increased radius R55mm over the Pre 1995 Quadrant (black) R40mm.
The following mods need to be carried out when fitting the white quadrant, if not the pedal will sit too high. Count 10 teeth up from the lower edge of the quadrant.
Using a hacksaw cut along the line of the rib to the centre boss.
Cut at right angles to remove this section.
Add the M8 locknut supplied in the clutch kit to the pedal adjuster bolt.
Fit it back to front, this will prevent the bolt slipping off the quadrant during clutch actuation.
Adjust the bolt until the desired pedal position is achieved.
The increased radius of the white quadrant allows for more travel at the release bearing, hence improving clutch release/gear selection.
Important Note
AP Racing CP3560 Cover Assemblies should only be used in conjunction with our recommended driven plates (see below) and not with OE or alternative driven plates.
CP3560-1 cover can be used with CP5351-16 organic driven plate or CP5354-15 cerametallic paddle driven plate.
CP3560-2 cover should only be used with the CP5351-38 organic driven plate (uses flat segments) or CP5354-15 cerametallic paddle driven plate.
Failure to comply with any of the above recommendations is likely to result in release problems with your clutch.
More Associated Content
Flywheel Kits And Clutch And Flywheel Kits
![](http://www.apracing.com/pics/productpics/epm005.jpg)
The Ford Part Numbers for these parts as follows:-
Adjustable Pedal - 1029012
Quadrant - 1029013
![](http://www.apracing.com/pics/productpics/epm008.jpg)
If vehicle is already fitted with adjustable pedal and white quadrant then mods below will not be necessary.
Quadrant - 1029013
![](http://www.apracing.com/pics/productpics/epm006.jpg)
![](http://www.apracing.com/pics/productpics/epm010.jpg)
Important Note
muz
30-09-2015 08:29 AM
