help please rst wont start
Old Aug 3, 2008 | 06:00 PM
grant_xr's Avatar
grant_xr
Default help please rst wont start
ive just got my engine conversion to the point where it is ready to fire but it wont lol.
its an efi cvh turbo engine running ofab management and cossie fuel pump. it looks like there is no fuel getting injected into the bores. theres fuel at the rail and the injectors are pulsing. could it be that the fuel is constantly getting returned? has anyone experienced this problem before?
Grant
Old Aug 3, 2008 | 06:16 PM
s1cab's Avatar
s1cab
is it sparking correctly??
s1cab's Avatar
s1cab
as in 1-3-4-2 ?
Old Aug 4, 2008 | 06:30 PM
grant_xr's Avatar
grant_xr
yeah mate its sparking correctly. the spark is fine, the prob is theres no fuel being injected into the cylinders??
Grant
Old Aug 4, 2008 | 07:39 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Just a thought.
Have you checked how much pressure you have in the fuel rail?
You may have fuel there but not enough pressure.
Just seems strange that you have fuel physically there and a injector pulse but still nothing to the cylinders.
Old Aug 6, 2008 | 06:34 AM
grant_xr's Avatar
grant_xr
ive not checked what pressure is there as i dont know what it should be mate. ive realised that the vaccum hose from the inlet that connects onto the nipple in the fpr hasnt been fitted. would this prevent it from gettint fuel into the bores? i was reading that the fpr works out the pd from the pressure in the rail and the vaccum from the inlet to regulate the fuel but with the inlet vaccum disconnected would it be fully open and constantly return to the tank?
Does anyone know what pressure should be at the rail? Ive also got the fuel pump relay wired up to a perm ign feed for just now so it dosnt prime the fuel it constantly pumps fuel while the ign is on but i dont think this will matter will it?
Grant
Old Aug 6, 2008 | 06:44 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Not 100% sure what the pressure should be but it should run with the vac pipe disconnected.
Shouldnt matter about the relay for the minute but I would wire it up correctly once you've found the fault.
Old Aug 8, 2008 | 03:05 PM
SafeChav's Avatar
SafeChav
what car are you converting into? How do you know the injectors are firing?
Old Aug 8, 2008 | 05:03 PM
grant_xr's Avatar
grant_xr
its into a mk2 xr2 mate, ive removed the injector plugs ang tested the pulses with an l.e.d it still dosnt tell me if the injectors are firing tho.
grant
Old Aug 9, 2008 | 09:16 AM
SafeChav's Avatar
SafeChav
Have you got the main fuel and return lines the right way round
Old Aug 9, 2008 | 01:31 PM
grant_xr's Avatar
grant_xr
yeah mate defo the correct way round. gonna have a look at the wiring again and check the fuel pressure.
grant
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
