help on cleaning mongoose exhaust
Old Jul 30, 2008 | 08:27 PM
andy130's Avatar
andy130
Default help on cleaning mongoose exhaust
as above thanks andy
Old Jul 30, 2008 | 08:37 PM
R5COS's Avatar
R5COS
start off with brillo pads and a bucket of warm water to remove the heavy stuff then get a buffer with a compond head ie hard sponge type and lots and lots of metal polish (as you will need a good bit) then sit and relax for a couple of hours while you buff away, it can be done by hand but i wouldnt fancy doing it this way. go to midways in my resto (tread below) and you will see before and afters
Old Jul 30, 2008 | 09:50 PM
dakar's Avatar
dakar
I used wire wool and t cut together on mine and it came up mint
Old Jul 31, 2008 | 09:45 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
2nd that!
Old Jul 31, 2008 | 10:07 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
brillaint i am away to do that to mine tommorow
Old Aug 1, 2008 | 07:52 AM
boost mad's Avatar
boost mad
i used an abrasive polish or something like autosol with kitchen roll
Old Aug 1, 2008 | 09:28 AM
James_RScos's Avatar
James_RScos
I took mine to the metal polishers, now i just polish it will autosol about once every two weeks or when im out in it.
Old Aug 1, 2008 | 02:21 PM
dakar's Avatar
dakar
Fook me thats shiney
Old Aug 3, 2008 | 08:36 AM
cossie604's Avatar
cossie604
Who did you use James, with you being fairly local to me and all that?
Ive got a few bits down at RollsRoyce at present but their back door stuff seems very slow recently
Old Aug 5, 2008 | 08:52 AM
James_RScos
Hi Stu,
There a Refinishing Place down colwick im told there the best in the midlands and i can beleave it from the work they produce.
will find the name and number for you got acard in my folder from the rebuild project.
http://www.multimap.com/maps/#map=52...ited%20Kingdom
there workshop as i remember it is inbetween Grainger Street and Holme Street.
if you PM me your number i will txt you the detail when im down my garage next.
JK12
33
Apr 26, 2021 12:09 PM
chowfornow
14
Jan 5, 2019 09:01 PM
Cosnada
Jan 7, 2016 05:30 PM
A.t.p
Sep 29, 2015 05:04 PM
Adam Graham
Sep 6, 2015 06:04 AM
