boost problems
Old Jul 30, 2008 | 11:09 AM
webby80's Avatar
webby80
Lightbulb boost problems
bought a new 91 plate s2 3 weeks back and since ive had it had no end of boost problems . the car has under gone a full rebuild over the last year and when the previous owner put it back together i think he rushed it . the engine is speced as follows piper285t cam , hybrid t3 , -31 actuator , kn , mongoose chipped , and a bloody bleed valve . the problem i have is no matter wot the bleed valve is set to the car will only pull just under half a bar of boost and tails off quickly it also makes wot can only be described as a jet engine noise when boosting ( not sure if this is because of the hybrid as all the s2's i have had in the past have been same sort of spec but on a standard turbo and no bleed valve ) . it also seems to to hiss more than whoosh when the dump valve goes off had loads of turboed cars with bailey twin piston valves on b4 but never one that sounded like that .
my thoughts are that either the actuator is going week or the dump valve is ?
any ideas would be most appreciated guys
Old Jul 30, 2008 | 12:50 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Change actuator and throw chump valve in the bin.....go from there
Old Jul 30, 2008 | 01:11 PM
rs-nut-john's Avatar
rs-nut-john
I had a jet sounded turbo on my last one turned out id killed it through to much boost (needless to say ill not take it to that tuner EVER again)
My guess is that the Act is poor, or the bottom turbo hose tends to colapse under load restricting air flow, they also split after time so check that its not pulling air in anywhere.
Dump the dump valve because i dont care how good they are they can lead to so many probs that point else where.
Old Jul 30, 2008 | 01:37 PM
webby80's Avatar
webby80
removed dump valve and plugged the hole and the vacum ..... did exactly the same just instead of dumping it maded the waste gate chatter with turbo stall , wot about doing away with the bleed valve there is still an amal valve on the car all wired in with just the 2 hoses off and joined to the bleed valve?
Old Jul 30, 2008 | 01:39 PM
webby80's Avatar
webby80
are we thinking actuator then lads?
Old Jul 30, 2008 | 02:46 PM
rs-nut-john
Have you checked the hose on the bottom of the turbo ?? there prone to collapsing under boost reducing air flow/boost.
I would take off the bleed valve and reconect the amal valve back up (although these rarely work right) and see if it is that which i doubt it will be m8..
other than that looks like Act is weak and a run out to the Ford Fair is on the cards for a nice new one
Old Jul 30, 2008 | 06:04 PM
webby80's Avatar
webby80
Angry
haha my thoughts exactly mate
just need to sort fuel pump out now as that has now decided to pack up
Old Jul 31, 2008 | 08:26 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Never rains only pours with these
Hopefully the relay least its a quick fix....
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
