cold start problem
Old Jul 26, 2008 | 05:32 PM
blue rims's Avatar
blue rims
Soup Dragon
Default cold start problem
good evening people i have a s2 escort turbo h plate n when i start it from cold it runs fine 4 bout a minute n just keeps dying then untill it warms up properly then ok! then wen drivein it 1 min itll tick ova sound then the revs will drop to low n to mins later will rise far to high, its been played with alot and tuned so do you think it just needs a profesional set up? thanks.
Old Jul 26, 2008 | 07:36 PM
SafeChav's Avatar
SafeChav
i would lay money on it that its an air leak.
Old Jul 29, 2008 | 05:28 PM
diesel's Avatar
diesel
i had the same problem with mine and never found out what it was, i hope you find out as i still got my s2 in the garage
i remember it did my head in getting in and out the car (ALL THE TIME) turning the throttle up and down plus i had the starter problem were it wouldn't spin when warm so i kept getting stuck at lights looking like a nob
GOOD LUCK YOU WILL NEEED IT I TRYED EVERYTHING!!!
Old Jul 30, 2008 | 04:13 PM
SafeChav's Avatar
SafeChav
Sell it to me cheap
Old Jul 30, 2008 | 09:09 PM
blue rims's Avatar
blue rims
Soup Dragon
no chance lad its a minta!
feeling like a zetec conversion in the winter!
Old Jul 31, 2008 | 12:05 AM
blue rims's Avatar
blue rims
Soup Dragon
I was thinking off fitting a..
Old Jul 31, 2008 | 01:49 AM
Khooper's Avatar
Khooper
My opnion on this issue is that the idea behind "warming up" a car in the mornings used to be because driveability was so bad that if it didn't run for awhile it would stall out. The idea of NOT warming up a car in the morning is that a cold engine has loose tolerances.
________________________
Don't want a Bloody Car, then
Drive safely and Smile Freely
Old Jul 31, 2008 | 03:10 AM
blue rims's Avatar
blue rims
Soup Dragon
Old Aug 1, 2008 | 09:09 PM
SafeChav's Avatar
SafeChav
You know you want to
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
