Can you take a cam....
Old Jul 19, 2008 | 10:21 PM
picky775's Avatar
picky775
Default Can you take a cam....
out of a cvh efi head from the pulley end or does it have to come out the coil pack side??
Old Jul 19, 2008 | 10:23 PM
gup's Avatar
gup
coil pack side fella iirmc
Old Jul 19, 2008 | 10:25 PM
picky775's Avatar
picky775
Will it not come out the pulley side??
Old Jul 19, 2008 | 10:29 PM
gup's Avatar
gup
no as the hole is slightly smaller i think it seems to pull out but then it gets caught up
also you havent got the room to pull it out of the pulley side due to the inner wing or inner bit cant remember what its called lol
Old Jul 19, 2008 | 10:32 PM
picky775's Avatar
picky775
Cheers fella just didnt want to take the core plug out from under the coil pack as i wont be able to use the car once ive checked the cam and removed the core plug as i wont be able to pick one up till monday
Old Jul 19, 2008 | 10:42 PM
Rick's Avatar
Rick
u can re use it mate, done it loads - just be careful
Old Jul 19, 2008 | 11:48 PM
xr4x4rs's Avatar
xr4x4rs
isnt it just a plastic cap, just aseal can be re used again as said
Old Jul 20, 2008 | 10:00 AM
crazycage's Avatar
crazycage
my cvh one was plastic ,ill have a look in my garage i mite still have it mate
Old Jul 20, 2008 | 10:55 AM
picky775's Avatar
picky775
Ok cheers peeps the weather here is bollox anyway so will try get it done one evening
Old Jul 20, 2008 | 12:13 PM
DazC's Avatar
DazC
Taking the core plug out is easier than taking the head of even if you could get the cam out from the pulley end!!
Just leave the core plug in and get the cam mobile. Then use the camshaft to knock out the core plug by tapping the pulley end with a hammer gently.
Alternatively, if you are just checking it (lobe wear?), why don't you just remove all the followers and rotate it around so you can see down the follower bore?
JTECH James
142
Oct 17, 2008 12:59 PM
bonus_boy
Mar 25, 2007 01:37 AM
Carlsworth
Apr 3, 2006 11:18 PM
RS Grant
14
Feb 24, 2005 04:57 PM
