cossie fuel pump connections..leaking.
how the hell do you stop these bastards leaking. its the banjo connection and union nut. they're brand new with new washers, i just cant stop them weaping fuel, can anyone give me a good tip on how to stop that, cheeRS,
Richie.
Richie.
had the exact same problem on mine recently with old banjo bolts; replaced the whole lot with new banjo bolts and hose -
little tip is to get a pair of grips on the fuel filter hex and do the bolts up super tight; just be careful not to pinch the hose
needs it if you havent already.
i'll get under there tomorrow and have a look as its horrible outside .Is there any sealer that you can get to help seal the joints as you tighten it up.???
cossie09
Sep 14, 2015 04:21 PM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
