very strange problem with my 2wd saff??
Old Jul 7, 2008 | 08:14 AM
jamesers20004x4's Avatar
jamesers20004x4
Default very strange problem with my 2wd saff??
hi all,
when driving along the engine cuts out? rev couter falls to 0 revs engine is off? clutch is fully up then it just starts back up again? its really weird!
its happens when just driving normally no bumps, not after accellarating just normal motoway driving. its happened at about 60MPH and 40MPH.
Had the battery off the other day but have checked and checked again the connections and they are solid!
anyone got any ideas what could be causing this problem??
thanks
Old Jul 7, 2008 | 08:30 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Dodgy TDC sensor or connection ??
Or coil/ignition amp, engine earth etc ?
Could be lots of things, have you changed anything jus before it started happening ??
jb
Old Jul 7, 2008 | 08:56 AM
Stu @ M Developments's Avatar
PassionFords Creator
Ignition amplifier failing is most common. Obviousy any connection problems can cause this, but the IGNAMP is the common one in my experience of this issue.
Old Jul 7, 2008 | 09:04 AM
marco polo's Avatar
marco polo
hi james
as stu said , it also could be where the car loom joins the engine loom , thats what was wrong with mine same simptoms
marco
Old Jul 7, 2008 | 09:33 AM
jamesers20004x4
hi people,
thanks for the replys. How serious a problem is this? is it easy to fix or a bastard job?
All I did was take the battery off to charge it then put it back on!! although the wife then took it for a run and left the fooking lights on!! had to jump it of a diesel passat! could jumping it have caused the sensors to fail??
Is it at some point just not gonna start?
where would I start with the problem? Ignition amplifier, coil or TDC sensor?
thanks
Old Jul 7, 2008 | 10:20 AM
cozmeister's Avatar
cozmeister
More boost Igor!
The TDC sensor is quite easy - just need to get underneath the front of the car. The connector breaks down first because it's old and exposed to the elements. If it becomes disconnected (ie by bouncing about while driving) the ECU doesn't know when to fire, and things stop running. Wiggle the connector with the engine running, and if it cuts out, there's your problem. It's restarting again while your driving because you're effectively bump starting it.
Old Jul 7, 2008 | 10:56 AM
As said do a wiggle test, the sensor itself rarely fails, mostly just the connector pins get slack, the pins can be pushed together a bit more but won't last, new connectors can be put on from the likes of polevolt.co.uk, or solder direct.
Old Jul 7, 2008 | 12:08 PM
jamesers20004x4
Talking
Thanks again,
Im a bit of a numpty when it come to stuff like this!! can you try and direct me to exactly where the sensor is? I have no idea what im looking for!!
pics would help!!!!
thanks
Old Jul 7, 2008 | 12:15 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Down on your hands and knees, my friend
Find the crank pulley with hopefully all four teeth in tact at the front of the engine.
On the right (looking from the front) is a bracket, with a device pointing at the pulley - this is the TDC (Crank Position Sensor). It will have a 6 inch cable coming out of the back of it, which meets up to the loom with a 2 pin multiplug. Wiggle and play with this multiplug with the engine running. If the engine cuts out, there's your problem.
Old Jul 7, 2008 | 12:31 PM
Ignition amp is next to teh battery. Secured with 2 screws. Item is Ł40.
Old Jul 7, 2008 | 12:44 PM
cozmeister's Avatar
cozmeister
More boost Igor!
And the coil sticks out like a sore thumb in front of the coolant header tank - of all the places!
Old Jul 7, 2008 | 01:07 PM
jamesers20004x4
Cheers guys!!
will check this at lunch time!! bit of luck its the TDC multiplug and I can just soldier it!!!
muchly appreicate all the help!!
thanks
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
tankybaby66
Aug 9, 2015 07:13 AM
muz
Aug 1, 2015 06:48 AM
