rev counter giving in corect reading.
how can i get my rev counter to stop giving me half readings?
i think its sumit to do with my car being a twin coil, i would switch the rev counter to 2 cylinder, but its only goes as low at 4 the one i got, and the 2 cylinder ones are expensive
cheers guys
cheers guys
This will sort your problem.
Altho there is no need for the zenner diode or the resisters after it.
If that doesn't work then use a 1k ohm resister after the diodes from a 12v supply to pull up the voltage while retaining the signal (if that makes sence)
No need for the zenner neither - its only there to protect the diodes from any back-emf from the tacho - and tbh, the 1N4004 diodes are more than capable of withstanding that and any reverse current
brilliant, gna try and get down maplin 2mz morning!
so i get the 2 wires, out the diodes inline, join the wire then attach to the tacho wire?
( sorry for all the questions, wiring om ok with, but this has had me stumped!)
and its 1n4004 ye not 1n4004s?
cant seem to find one eithout a number after it? any1 got a link to the maplin site with this diode on it?
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
