Gt35 turbo What spec engine?
I have a nice looking Gt35 turbo waiting to go on a yb
What spec would you recommend to make best use of it?
Low compression and loads of boost Or high comp to keep the lag to a minimum if thats possible.
The block's wire rung and will be long studded. Arp's all round on standard crank and rods. Unsure of what pistons and cams to use.
Cheers aaron
Cheers aaron
Depends what you want the car for really.
Not a YB man, but your going to want a well spec'd head and cam to get some decent ish spool.
I think most would say go for a 30.
A gt 35 is actually a pretty nice turbo, with super spool up, but it also depends on the rest of the engine and the power you want.
i have a gt35 with 1,06 exh and i get 0,1bar @ 3k and full boost @ 4500 and that is on a engine that is only made for top end power, try with a .82 exh and engine made for midrange....
It's going in a r-e-d escos shell, and will be used for track days,sprints and the strip.
Will be rear wheel driven too.
drivability is not an issue, it's not a daily drive.
Just want the best results I can get really. It's going to stay a 2 litre, what spec pistons and cams do you think would be best?
cheers aaron
cheers aaron
a gt35 us a 600+ bhp turbo and 450-460 ft-tq on a 2litre
i wouldnt really use standard rods ona engine like this
and you would want a decent piston ie cosworth or cp ? or any other good make ?
also lowish compression will be safer on a wire rung block !
imo!
imo!
Don't be confussed kelv It makes sence to me.....
Rs500's have a turbo on them able to push 550bhp and they only run 220bhp standard?
If I have a turbo good for 600Bhp and run 500Bhp I think it should work well enough.
you don't have to be Finish, danish or swedish to run a large turbo
HOMOLOGATION
look it up...
I ran a GT35.... great for Top end power and with a PROPER 6 speed dogbox to keep it on the boil and some solid lifters OR a bigger capacity engine then yes they work well for a trackcar
On a standard 2litre YB the GT30 is a MUCH MUCH more driveable and FUN Turbo in my experience on both road and track. Its also made the Sierra a FASTER track car in my opinion.... more power for more of the time! more driveable and controlable. Just Suits a 2.0 YB alot better in my experience.
I love my GT30 and should have switched years ago!
HOMOLOGATION
look it up...
look it up...
...What GT 30 you running Lee?
Martoon is currently delevoping his own GT32.5! for those GT30 owners wanting that bit more!
Obviously it will be tested on some proper cars on track and road and on his new Dyno Dynamics rollers.
I bet it will be the nuts
Is there nothing in the current Garrett range that will cover the performance he wants?
No offence to Martin but i find it hard believe a garage in brum can develop something so much better that, Garret haven't already cattered for?
There is a bit of a hole in the garret range for a high 500s turbo as far as im aware.
all martin is likely to be able to do is mix and match the cold and hot sides from different turbos id imagine, so not developing his own housings or anything like that.
clearly not or he wouldn't be trying!
Garret don't produce specific Turbos for specific spec engines do they. Its not cost effective or profitable to 'tailor' that specifically.
Its just like the modified T4's AVA have been doing on Euans engine and he is getting some great results.
Cheers aaron
Cheers aaron
You will need a very good flowing engine to make it work best without surge, Some people claim its not a good turbo but this is down to the way it is being used and them not knowing how to stop the surge,
Compression wont have much effect you can be down to 7-1 or up at 8-1 but you will need to know a bit to have a good package at 8-1.
Mark
Mark
https://passionford.com/forum/showth...light=autronic
Graphs have gone but will find them tomorrow.
Mark
Mark
The engine is only as safe as the mapping and componants are good for,
Done a few now
Mark
Not looking for an argument but why does it sound like there's surge here?
http://smg.photobucket.com/albums/07...t=MOV02066.flv
Mark
