Gt35 turbo What spec engine?
#42
Just thought i'd check, as the boost gauge was still wrapped around off the clock
When you say you get no surge, what kind of wastegate duty do you run in the midrange? I.e. I can run above what i've got at the limiter in the mid range with no surge, unless I floor 5th gear, (obviously been my own car i know not to do this)
#44
On the original thread i said it sounds like part throttle surge. I run a 35 on my Evo and get exactly the same under light throttle in higher gears.
Mark
#48
Happens alot on big turbo cars as you have the foot to the floor to bring the turbo on full boost then have to lift almost insatntly as you realise you dont really need 2 keep foot down as the acelleration is more than enough on half throttle.
#52
Colossal Pervert
No, the turbo isn't aware of your throttle angle. Surge is surge.
Personally i'd run a more suitable turbo, like a T61 than these 'too efficient' GT turbos that aren't versatile enough for smaller displacement engines!
#53
Mark
#54
I know the turbo doesnt know what angle your throttle is but you can hardly spec a turbo for an engine on quarter,half or three qurter throttle can you?!
If you start in any gear at low revs and floor the throttle and the pull isnt smooth and the turbo surge's or stalls altogther then its poor turbo choice but on anything other than full throttle its alot more difficult.
#55
Colossal Pervert
#56
Guest
Posts: n/a
That bit of film was my letting of in the rain
Have overcome that now full throttle all the way
Cant wait to see what the next turbo does
#57
You can have the best of both worlds if you try hard enough.
No point having a nice driving car if its 100 bhp down on where it should be.
#60
#63
#68
Not 100% sure what ones it was he tested would have to try and find the threads Mike posted.
Tony why do you think people get carried away over it? I have only ever seen BHP increases from dropping back pressure so I think its right to concentrate on it.
#79
B1mbo
harvey did the back to back on paul ripleys engine using the gt 30.. < not sure but was external wastegate
did it with the .82 and .63 housing
the graphs
0.82 a/r turbine housing
RPM Bst BP Torque BHP
3000 08 04 199.7 116.9
3500 28 15 360.5 242.7
4000 32 20 386.3 293.1
4500 32 21 404.9 348.7
5000 32 24 394.9 374.7
5500 32 26 394.4 414.7
6000 32 28 395.1 450.7
6500 32 32 389.6 483.7
7000 32 35 376.3 501.5
7500 32 40 341.3 485.4
0.63 a/r turbine housing
3000 13 10 238.8 138.1
3500 32 24 389.4 259.2
4000 32 27 388.3 297.5
4500 32 31 404.1 345.0
5000 32 34 397.0 379.7
5500 32 37 393.0 413.2
6000 32 39 398.7 457.9
6500 32 44 382.7 474.4
7000 32 56 370.8 495.6
7500 32 65 340.3 485.3
the graphs
