"quick" cossies... engine specs etc.
Old Jul 6, 2008 | 09:38 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Default "quick" cossies... engine specs etc.
right for years i have built cossies with huge turbo`s, external wastegates and mad boost but i find them useless compared to greys/t35, has anyone got any ideas on a perfect car they could own? i was thinking 4x4, UT T38 30psi, cams/headwork, 9.0:1 CR live map.
just curious on thaughts
anyone run a similar spec car?
Old Jul 6, 2008 | 09:50 AM
allsteel's Avatar
allsteel
Mine might be similar Sean,once i can get the bloody thing mapped.All the tuners say you will have to cap the boost on a 9.1 Cossie though.
Old Jul 6, 2008 | 09:53 AM
Mr C's Avatar
Mr C
I would say Martin Hadlands ESCOS in white when it ran everything for 550bhp and 180+MPH but he swapped engine briefly for a stage3 330bhp engine that did the 3rd quickest 0-100MPH at the time... best of both world IMO. its not the engine that sorts the time and performance, ask martin and Danny B- 12sec car on a stg1
Though at Martins level now extra power is always welcome seeing as he has the chassis to take it
Old Jul 6, 2008 | 10:08 AM
Cossie Sean
Mapping will be a pain but i know a chap called Lindsay Shaw (ex WRC carlos sainz/colin mcrae mechanic) and he knows a thing or two about 9.0:1 cossies and mapping them hopefully see some good results on WRC cams i reccon.
there was a chap at york dragway ford event a while back could have won if lighting sequence wasnt screwed up and he was only on stage3, ran mid 12`s and york is a very very poor strip.
i ran a 13.2/107mph on greys and t3, terminal proves how bad strip was, after 2nd gear it drops to concrete, wheelspin city lol.
Old Jul 6, 2008 | 10:36 AM
XRT_si's Avatar
XRT_si
How do you mean you find them useless? Laggy?
Old Jul 6, 2008 | 10:42 AM
Cossie Sean
just in general, laggy, miss a gear and get them off boil and you loose!
side by side race with a stage3 or grey`d cossie i would probebly loose upto 100 120 mph.
depends what your useing the car for i guess but for me i think smaller is better.
gonna rebuild the bottom end and get the car down to ford fair and make my decision there, see whats for sale if i decide i want something different.
Sean.
Old Jul 6, 2008 | 11:12 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
the spec of my engine is a good one
Old Jul 6, 2008 | 11:26 AM
col cos1's Avatar
col cos1
i know what you mean mate,mine is low comp t4 bd14`s etc and takes a bit to get it going compared to lesser specs but once it is on boost,you need both hands on the wheel lol
Old Jul 6, 2008 | 11:30 AM
mechanic28's Avatar
mechanic28
mines standard c/r,mild porting,beleive standard cams,500 intercooler etc,T34.55,light blue motorsport injectors,live map at NMS 30psi spike 27 in the midrange 23psi at 7k
Stavros's Avatar
Stavros
DEYTUKURJERBS
use nitrous to wake it up, have it switch off once its on boost, job done.
or, if you using lairy ones, use shorter duration cams.
but T35/greys/2bar is a lovely engine that drives nice and beats most stuff out there, no doubt, loved mine.
Old Jul 6, 2008 | 11:35 AM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Agreed fully - I had standard comp, standard head and cams, Greys, NMS map, T34 .63.
Punchy as hell, great to drive all the time. Was 371 bhp and felt the quickest most of the time even compared to my later 420 and 467 bhp conversions.
Shame the engine was on 100k + miles and was using more oil than petrol. Should have kept it as it was though - could have saved a fortune.
Although 467bhp was fun when on song....
Si
Old Jul 6, 2008 | 11:36 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As Stav says, nitrous is the key. Although lots of different ways to use it.
My T34+125bhp setup I was running was nutty, when you hit the throttle it took off more responsively than a ST escos, and it had the pull of a T4.
Downside to that was 50p a second for the nitrous.
Old Jul 6, 2008 | 11:42 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
as said,totally transforms the performance of my escos
Old Jul 6, 2008 | 11:53 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
How long does that last for? and does it only kick in when on full throttle?
Old Jul 6, 2008 | 12:12 PM
kitchy's Avatar
kitchy
RS2000 4x4
and your diff
Old Jul 6, 2008 | 01:49 PM
StephTell's Avatar
StephTell
My ideal cossie would be a 2wd Saph with a 9" 4.4 diff, 5 or 6-speed dogbox and a small turbo engine, converted to proper management running greys and a .55 T34 on max.boost
Old Jul 6, 2008 | 01:54 PM
Chip's Avatar
Chip
About 2 minutes for a large bottle.
And yes only on full throttle.
If used on a big turbo then it makes a lot of sense doing as stav says and using it only for "anti lag", plus then when it runs out your car is still quick, just less responsive.
Amazes me that anyone who spends a lot of money on their YB doesnt have nitrous, I really cant imagine why it wouldnt be wanted, people say stupid stuff like "it runs out" but when it runs out its only the same as not having it, so why have it none of the time when you can have the option?
Old Jul 6, 2008 | 02:38 PM
Lloyd's Avatar
Lloyd
Originally Posted by kitchy
and your diff
cheers for reminding me mate, at 1k a time it gets expensive.
Old Jul 6, 2008 | 02:56 PM
BLACKCOS's Avatar
BLACKCOS
you got your diff sorted out yet m8?
Old Jul 6, 2008 | 03:11 PM
Lloyd's Avatar
Lloyd
yes mate,picking it up thursday.
Old Jul 6, 2008 | 04:00 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine uses a T34.55, 400s, 7.8.1, mild head porting and standard cams. Only peaks at 24psi but i have still done the 1/4 in 12.91 @ 114.77mph.
Made 372bhp on a Dyno Dynamics RR holding 21psi at the limiter.
Steve.
Old Jul 6, 2008 | 05:40 PM
foreigneRS's Avatar
foreigneRS
Testing the future
what does 'proper management' mean, and how do you expect it to make any improvements?
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Oct 9, 2015 07:38 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Graceland
Jul 31, 2015 10:34 AM
