which head gasket????
Old Jul 1, 2008 | 02:17 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
Default which head gasket????
I have a s2 rs turbo which has a 1900 bottom end, the piston bore is a shade over 83mm, spoke to speed shack and the payen head gasket is 83.1mm bore which means that it may be no goos, so I may have to use a felpro group a jobbie which I dont want to do as ive just removed one after failing after just 1500 miles with 500 of them at 11 psi
any help would be great
Old Jul 1, 2008 | 04:07 PM
turbo's Avatar
turbo
Standard ford.
Old Jul 1, 2008 | 05:13 PM
Noisy Boy's Avatar
Noisy Boy
Originally Posted by turbo
Standard ford.
YEP YEP!
Old Jul 1, 2008 | 11:28 PM
Chris69's Avatar
Chris69
at 83mm your pushing the standard ford item, i'm pretty sure its only about 82.5 or something so off limits.
i agree on felpro being crap, my last engine needed 86mm and i was stuck and had to order felpro at great expense, the quality was very bad when compared with ford/payen gaskets imo
not much help sorry but away from 80mm or 2litre 85/86mm zetec there ain't a huge amout out there, correct me if wrong but i did have good look around
Old Jul 2, 2008 | 12:02 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
you're wrong
this cometic may cover it:
http://cgi.ebay.co.uk/COMETIC-FORD-C...d=p3911.c0.m14
but if not, ask him if he can get a larger bore one... he got one for my zvh (85mm)
Old Jul 2, 2008 | 07:22 PM
bad boy rs's Avatar
bad boy rs
Got a felpro on my 2.1 zvh never had a problem
Old Jul 2, 2008 | 07:35 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
use a cornflake box,better then a felpro
Old Jul 3, 2008 | 12:50 PM
Raj B's Avatar
Raj B
the problem is that I have a 1900 bottom end, i think felpro is the only one that will fit???
Old Jul 3, 2008 | 12:58 PM
Noisy Boy's Avatar
Noisy Boy
felpro, better off using your under pants!
Old Jul 3, 2008 | 02:08 PM
Gary_Hurn's Avatar
Gary_Hurn
i d never ever use a felpro
Old Jul 3, 2008 | 04:10 PM
bad boy rs's Avatar
bad boy rs
I could only use the felpro one as its the right size, or you can spend 200quid on one from sitec racing, ive herd plenty of bad things but never experienced them
Old Jul 3, 2008 | 10:54 PM
Chris69's Avatar
Chris69
Originally Posted by MD Cos
you're wrong
I don't mind being proved wrong if it helps but if you didn't know, that ebay Ad said upto 83mm so unless you knew thay did larger bores i doubt you'd bother with it with his spec as described above
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
