Where is temperature transmitter
Old Jun 16, 2008 | 03:37 PM
captiva's Avatar
captiva
Default Where is temperature transmitter
Switched on the ignition only and the temp gauge went right off the dial so assuming it is the sender unit where is it on a 4x4 Sapphire Cossie, not that I have much chance of getting one over here but may be it cross references with a Mustang of Thunderbird or something like that as a sender is a sender aint it?
Old Jun 16, 2008 | 04:36 PM
LHD220Turbo's Avatar
LHD220Turbo
turbo side of the head at the front, single wire going to it, easy fix, 1/2 inch spanner and have the replacement in your hand ready to screw in as water will come out. if you lose lots of water dont forget to top up the header tank
edit to say MSD or matt lewis off here sells them
Old Jun 16, 2008 | 04:41 PM
Carnt miss it fella its on the left hand side at the front on the turbo side as said above.
Old Jun 16, 2008 | 05:03 PM
captiva's Avatar
captiva
I aint got one there not even a wiring harness only going into alternator. Have got 3 at the back of the engine inlet side , one is ECT sender plus 2 more may be oil pressure and the other one might be temp. Is 4x4 (200 block) different from 2wd (205 block) as to where the sender is?
Old Jun 16, 2008 | 06:07 PM
jon@work's Avatar
jon@work
water temp gauge sender position :
2wd head - front turbo side of head
4x4 head - rear inlet side of head
Old Jun 16, 2008 | 06:23 PM
LHD220Turbo
didnt realise they differ from the 2wd to 4x4 heads
Old Jun 16, 2008 | 06:44 PM
captiva's Avatar
captiva
Thanks peeps.
Old Jun 17, 2008 | 04:44 AM
As said 4wd is on the inlet side of head at rear in the little alloy bit that the heater pipe goes onto.
Old Jun 17, 2008 | 07:04 AM
sorry people i was thinking about a 2wd head ops
Old Jun 17, 2008 | 11:47 AM
jon@work's Avatar
jon@work
that's for the ECU not the gauge
Old Jun 17, 2008 | 09:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
gauge going straight to max. indicates a short circuit to earth. could be the sender, but also check the wiring has not been nipped anywhere
Old Jun 17, 2008 | 09:51 PM
LHD220Turbo
mine was like this; you could wiggle the sender and the insides were moving about freely - easy fix as said
Old Jun 17, 2008 | 11:23 PM
captiva's Avatar
captiva
Tried to pull the wire connector of and the sender came to bits Guess this is the problem but why oh why did they put the sender in first and then build the car around it!! What to take off first, oil filter, plenum chamber, inlet manifold or engine out got any ideas?????
Old Jun 18, 2008 | 04:13 AM
stevecossy's Avatar
stevecossy
Ya can get it out without taking any of that stuff off, its a bit tricky but just use a deep socket and extention bar etc.
Good luck regards steve.
Old Jun 18, 2008 | 04:17 AM
stevecossy's Avatar
stevecossy
Thats the ECT sensor mate and the gauge sender is above
Old Jun 18, 2008 | 04:25 AM
captiva's Avatar
captiva
Wot size socket is it, and I am good to go.
Old Jun 18, 2008 | 04:51 AM
stevecossy's Avatar
stevecossy
Think it is 13mm fella.
Old Jun 18, 2008 | 07:58 AM
LHD220Turbo
1/2 " i believe
Old Jun 18, 2008 | 10:02 AM
stevecossy's Avatar
stevecossy
Either 1/2 inch or 13mm should be ok as nearly same mate.
Old Jun 19, 2008 | 04:32 AM
captiva's Avatar
captiva
Thanks guys
Old Jan 3, 2010 | 05:18 PM
Shredtheibanez's Avatar
Shredtheibanez
Default Haha, Got the same problem
Blantantly my new signature! haha
Back to subject, I have the same issue, gonna replace the sender, probs the problem. Thanks for the advice all.
Derek Burleigh
Sep 16, 2015 06:27 PM
oilman
18
Mar 16, 2005 03:47 PM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:44 AM
foreigneRS
Jul 20, 2004 11:06 AM
L33 BYT
Jul 6, 2004 09:25 PM
