What causes an oil to lose viscosity
How to make a complicated subject uncomplicated is not easy so I'll try to explain in the best way I can why oils degrade (shear) with use and the easiest way to identify an oil that will "stay in grade" for longer.
Viscosity Index Improvers.
An oils viscosity will decrease as the engine temperature rises. Viscosity Index Improvers are added to reduce this thinning. They are a key addative in the production of multigrade oils.
VI Improvers are heat sensitive long chain, high molecular weight polymers that increase the relative viscosity of the oil at high temperatures. They work like springs, coiled at low temperatures and uncoiling at high temperatures. This makes the molecules larger (at high temps) which increases internal resistance within the thinning oil. They in effect "fight back" against the viscosity loss in the oil.
"Shearing"
The long chain molecules in VI Improvers are prone to "shearing" with use which reduces their ability to prevent the oil from losing viscosity. This "shearing" occurs when shear stress ruptures the long chain molecules and converts them to shorter, lower weight molecules. The shorter, lower weight molecules offer less resistance to flow and their ability to maintain viscosity is reduced.
This shearing not only reduces the viscosity of the oil but can cause piston ring sticking (due to deposits), increased oil consumption and increased engine wear.
Like basestock quality, VI Improvers also vary in quality. The best quality ones are normally found in synthetic oils (Group IV - PAO / Group V - Esters) and it is important to understand that the less of these in the oil the better the oil will stay in grade.
Which oils require more VI Improvers?
There are two scenarios where large amounts of these polymers are required as a rule.
Firstly in "wide viscosity" multigrades. By this I mean that the difference between the lower "W" number and the higher number is large for example 5w-50 (diff 45) and 10w-60 (diff 50) are what is termed as "wide viscosity" oils.
Narrow viscosity oils like 0w-30 (diff 30) or 5w-40 (diff 35) require far less VI Improvers and therefore are less prone to "shearing".
Secondly, mineral and hydrocracked (petroleum synthetic oils) require more VI Improvers than proper PAO/Ester (Group IV or V) synthetic oils as they are less thermally stable to begin with and this is due to the non-uniform molecules in petroleum oils as opposed to the uniformity of synthetics built in laboratories by chemists.
It is a fact that some synthetics require little or no VI Improvers to work as a multigrade due to their superior thermal stability.
How to identify a good "shear stable" oil.
API and ACEA both conduct tests called HTHS (High Temperature/ High Shear) and all oils carrying these specifications are tested and scored.
For all oils, these test results are available however, they are often ommitted from the oils technical data sheet! Oil Companies have a tendency to publish the figures that they want you to see and therefore you often need to dig further or ask for certain information when comparing the performance of various oils.
High-Temperature/High-Shear
This test is a simulation of the shearing effects that would occur within an engine. In fact, it's actually designed to simulate motor oil viscosity in operating crankshaft bearings.
Under high stress conditions where shearing can occur, the VI Improvers (polymers) break down. As they do, the viscosity of the oil decreases. This is what the High Temperature/High Shear test checks for.
The HT/HS test is measured in Centipoise (cP) as the Cold Crank Simulator test is. However, in this case, because you're hoping for the least loss of viscosity with an increase in heat and stress, you want the cP value to remain high.
Each SAE multi-viscosity grade has a specific lower limit for the HT/HS cP value. If a multi-viscosity oil cannot achieve a cP value above that limit, it cannot be classified under that viscosity grade. For instance, according to the SAE specifications, an oil must achieve an HT/HS cP value of 3.7 or higher in order to be classified at the 15w40 viscosity grade.
The thinner the oil the lower the number.
Comparisons of HTHS numbers.
Here for comparison sake are a few numbers that we have compiled from data sheets and requests to the oil companies concerned. These are well known oils and considered to be "quality" synthetics so these comparisons are relevant.
Silkolene PRO S 5w-40
HTHS 4.07
Motul 300V 5w-40
HTHS 4.51
Silkolene PRO S 10w-50
HTHS 5.11
Motul 300V 10w-40
HTHS 4.19
Silkolene PRO R 15w-50
HTHS 5.23
Motul 300V 15w-50
HTHS 5.33
Mobil 1 Motorsport 15w-50
HTHS 5.11
Castrol RS 10w-60
HTHS 3.70
I'm sorry if this is too complicated but making a complicated subject simple is not easy however if I've lost anyone, please feel free to ask questions.
Cheers,
Simon
"Shearing"
HTHS 4.07
Motul 300V 5w-40
HTHS 4.51
HTHS 5.11
Motul 300V 10w-40
HTHS 4.19
HTHS 5.23
Motul 300V 15w-50
HTHS 5.33
HTHS 5.11
Castrol RS 10w-60
HTHS 3.70
Cheers,
Simon
First of all thanks for the read!!!
What u are saying here is that u are better off using a 0w-30 oil then using a 14w-50 oil ? as that's what i understand from it. As from how i understand and read its doesnt shear as much but say in a performance engine it will shear anyway as it gets too hot (over a standard engine) and then will require more VI Improvers?
Originally Posted by POPEYE
so what you are saying is that castrol is shit basically
The Castrol is labelled a synthetic but in fact it is not a proper one (pao/ester based), unlike the others mentioned here which is evidenced by the shear stability which meets the minimums required by API and ACEA.
In conclusion there are better oils out there.
Simon
Narrow viscosity is good
Synthetic basestock is good
Less VI Improvers is good
Simon
Did Someone Mention TUV
Originally Posted by oilman
Its a combination of a couple of things:
Simon
All I know is I've been well happy with the Silkolene Pro s 10w 50 I bought from oilman a few weeks back. Engine sounds and runs spot on.
Car comes back from the tuners today aswell, so will see how it copes with a bloody hot turbo
Simon
I personally think that the Silkolene PRO oils are excellent and represent one of the best money can buy quality wise but Motul have come a long way in the last few years and are catching them fast. There's also Mobil1, still a great oil.
5w-40 and 10w-50 are good grades depending on application and use.
Simon
http://www.opieoils.co.uk/lubricants.htm
Simon
Oilman very interesting read, could you do a simliar exlpanation for the "5W-40 etc" numbers
I.e which do you choose.
10w-40 or 20w-50 say they both had very simliar HTHS values
Many thanks
ryan
Many thanks
ryan
Many thanks
ryan
Many thanks
ryan
The figures should be compared within the same viscosity i.e. look again above at the 3 15w-50's I've listed they're all about the same.
The thicker the oil, the higher the number should be for example a 10w-60 should be higher than a 5w-40 all things being equal. By this I mean same basestocks in them - However as explained on many occassions, all things are not equal as there are synthetics and synthetics!
Hope this explains.
Simon
Originally Posted by J871yhk
Isn't mobil 1 very ashy or is that a myth?
alex
alex
Simon
That's a new one on me.
Synthetic 10w-40 is the same thickness as semi-synthetic 10w-40 and the same for all oil viscosities.
Viscosity has nothing to do with the basestock.
Whoever told you that clearly knows nothing about oil and is talking out of their ****
Simon
Simon
deathrider666
28-09-2015 06:12 PM
