Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
changing pinto engine
Old Jun 14, 2008 | 06:14 PM
davidra7's Avatar
davidra7
Default changing pinto engine
hey, my name is David, i'm from israel.
I have some questions about pinto engine. ihave 2000 pinto engine if i put Cosworth head in the engine but non turbo or injection , i want to stay with carb.
it will give me something ? more power? or it will be best to buy to this engine new cam and forged pistons? i what something like 130 hp, its enough to me
thanks
David
Old Jun 14, 2008 | 06:20 PM
costina's Avatar
costina
Live long and prosper!!
Best way and the cheapest is fit a performance cam,4 branch manifold,ported head,twin 40 carbs should see around 140 bhp
cossie head can be done but needs new raised top pistons,cams,exhaust manifold,carbs,loads of rework on head and will cost loads more
Paul
Old Jun 14, 2008 | 06:55 PM
davidra7's Avatar
davidra7
thanks pual, where in uk i can buy forged pistons not expencive with delivry to israel .
even batter shop in us with forged pistons
As above 140 bhp is nothing for a modded 2 L pinto 8 valve so stick with std head, instead of cossie head.
I got 138bhp from a 32/36 with modded head and + 90thou pistons, cam.
Old Jun 18, 2008 | 04:07 PM
costina's Avatar
costina
You won't need forged items std cast will be good for that power and upto 180bhp
Try
Rally Design
Burton power
HT racing
Jems
Paul
Old Jun 19, 2008 | 09:57 AM
davidra7's Avatar
davidra7
i have pinto engine type NBA so they say the CR is 8.2 or 8.4 i talked to some people i need something like 9.2 , sierra pistons are good?
Old Jun 23, 2008 | 03:12 PM
freddy1's Avatar
freddy1
I run a pinto in historic stage rallying. The bottom end is standard, just well built, lightened & balanced. The power is in the cylinder head. Mine is properly ported, polished with group 1 valves etc. With a Kent RL32 cam & twin 45's it makes a genuine (I see all sorts of crazy figures quoted) 150hp @ the wheels @ 7000revs (around 175/180 at the flywheel) and pulls from 3500 revs. For road use you would use a milder cam to make it more tractable and still get 120/130 @ wheels with a good head.
No need for forged pistons/ steel rods etc unless revving beyond 7000/7500.
Old Jun 28, 2008 | 09:00 AM
davidra7's Avatar
davidra7
my card eat a lot of fuel , somebody knot what jets puts in weber 32/26 dgav on pinto 2L, i need
1. main jet
2. air corrector jet
3. 2 idle jets
Old Jun 28, 2008 | 01:08 PM
Use somewhere around 130/135 mains in primary/secondary, air correctors around 170 primary, 125 secondary, idle jets 45.
Old Jul 12, 2008 | 04:25 PM
Alcatraz's Avatar
Alcatraz
Alcatraz
thanks
David
Hi David
I have done your modification before .... let me tell you what you will need...First of all you don't have to raise the pistons as from what you said ... the block is the standard pinto which runs at 9.2 : 1 compression ratio... if its a cosworth block ... then i reckon that you will have to go for the forged pistons as the compression is less than 9. . .If you want more power go for forged pistons and go to some engineer and put valve pockets in them...once you are done with that you will raise the compression to arround 10 something.... A nice set of Webers 40 DCOE with short reach manifold will do the trick .... then its a question of jetting them up .... you will need the right arrangement to get the best performance out of the engine....If you're thinking of putting in some camshafts please recall that you should not buy them for the TURBO version of the Cossie head... you should search for cams which are suitable for the Aspirated version of your head...... keep that in mind ... otherwise... you 're better not messing about with the cams....
Old Jul 13, 2008 | 05:56 PM
davidra7's Avatar
davidra7
http://www.esslingeracing.com/mercha...egory_Code=CCK
what are ou says about this cam?
me only problem is that i need to buy the cam from us.
in ford transit engine PINTO type NBA i has compression under 9? becuase in autodata it says 9.2.
forged pistons is to expensive for me at this moment.
big_Rad
Sep 15, 2017 09:36 AM
cameron2
Aug 25, 2015 07:18 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
