Head Thickness
Old Feb 4, 2004 | 06:08 PM
Default Head Thickness
What is the std head thicness for a 4x4 head
What is the minimum thickness it can be before it is rubish
(head thickness between top and bottom mating serfaces)
Thanks
Old Feb 4, 2004 | 08:08 PM
Guinnless's Avatar
Guinnless
138.68mm between mating faces.
Old Feb 4, 2004 | 08:33 PM
Is that std or the minimum ???
Old Feb 5, 2004 | 07:36 AM
Guinnless's Avatar
Guinnless
Minimum.
Old Feb 5, 2004 | 10:41 PM
So once the head thickness gets to 138.68 mil then its rubish and only good for the bin
Is this the same for all heads 2wd & 4x4 ?
Old Feb 6, 2004 | 12:38 AM
PJay's Avatar
PJay
once it gets to that thickness stick it on ebay as a n/a cossie head
Old Feb 6, 2004 | 01:25 AM
either sell it or stick a set of low comp pistons in it.
Old Feb 6, 2004 | 06:43 AM
Guinnless's Avatar
Guinnless
Or use a 'thick' Cometic gasket...
Old Feb 6, 2004 | 06:29 PM
So if you use low comps its not an issue ????
Old Apr 20, 2004 | 09:54 PM
mine is 137.8mm. there is no reason to bin the head. the only concern is the potential for valve to piston contact. lop some off the piston crown or get lowerc r pistons
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
