Engine fitting?
Old May 28, 2008 | 05:29 PM
h8ckyRST's Avatar
h8ckyRST
Default Engine fitting?
Hey all, I recently undertook the task of swapping my engine over in my erst, Unlike the haynes manual way of doing things i unbolted the engine from the gearbox and lifted the engine out no probs! when it came to fitting the new engine in it was an absolute nightmare!
After many hours of "in out, in out, shake it all about" i noticed oil pi$$ing out of the driveshaft where the ABS drive belt is and where it goes into the gearbox, Why is this?
And what is the best way of getting the new engine in!
Please bear in mind i only have a crane and a couple of jacks which don't get the car high enough to get it in from bellow!
Please help me guys!
Old May 28, 2008 | 05:39 PM
mark_24v_wiring's Avatar
mark_24v_wiring
Sounds like a driveshaft has come out of the box. drain the oil from the gearbox and take it out mount it to the engine and drop the whole lot back in the bay as 1 unit
Old May 28, 2008 | 05:41 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you take the shafts right out?? if you have thats why you got oil pissing out If you aint then you've probably pulled them out just enough so it leaks or the seal has gone
Old May 28, 2008 | 05:46 PM
h8ckyRST's Avatar
h8ckyRST
Cheers for the reply mate, How hard is it to get the gearbox out? Whats involved? i suppose while thats out i may aswell give it a re-build or should i leave it alone?
I'm no snap-on weilding genius, I'm a bricky by trade so could do with all the advice i can get really mate!
Old May 28, 2008 | 06:27 PM
adduk's Avatar
adduk
while you got the engine out get rid of the abs aswell as its crap and you can redo the brake lines with plenty of room.Also if you are going to be removing the driveshafts for any reason you may aswell fit new seals as there only few quid from ford and it saves messing later when they start leaking.
Old May 28, 2008 | 06:38 PM
h8ckyRST's Avatar
h8ckyRST
OK does this mean the ABS drivebelt can come off! also what else needs doing? with brake lines?
Old May 28, 2008 | 06:43 PM
adduk's Avatar
adduk
unless you want to redo all the brake lines you can just connect the master cylinder outlets to the two t pieces on the inner wing then use some of the abs tube to link out the abs outlets on the bottle,or if you have a 3i bottle just swap them and it saves linking out the two. then just take all the abs out and yes that includes the belts,thats what i did when i fitted my cossie brakes all round.oh but you need to connect the master cylinder outlets to the correct t piece,i will have a look at mine to see which one goes where as i cant remember off the top of me head.
Old May 28, 2008 | 06:46 PM
h8ckyRST's Avatar
h8ckyRST
Ok mate nice one!
Old May 28, 2008 | 06:57 PM
adduk's Avatar
adduk
Ok mate nice one!
the front outlet of the master cylinder must be connected to the nearside t-piece on the inner wing, and the rear outlet to the offside t-piece. then just take the bulb out of the back of the clock for the abs
Old May 28, 2008 | 07:35 PM
h8ckyRST's Avatar
h8ckyRST
Is this any use to me!
http://cgi.ebay.co.uk/ESCORT-1-6-RS-...QQcmdZViewItem
Old May 28, 2008 | 07:42 PM
adduk's Avatar
adduk
u dont need that just the bottle that pushes into the top.plus the rst use a 25 size i think
Old May 28, 2008 | 08:01 PM
h8ckyRST's Avatar
h8ckyRST
Thanks Guys i'll let you know how i get on then!
Old May 28, 2008 | 09:14 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
jack up the open end of the box up a little to help you drop it in and leave it out of gear, then get the angle of the engine the same as the box and it'll slip in like a boost bar in my fat gob
ive done dozens, they are always a chore but usualy cos the box to engine is a cnut to wiggle together
Old May 29, 2008 | 05:14 PM
fonfe's Avatar
fonfe
undo the gearbox mounting nuts that hold the mounts to the cradle. just undo them and take them off, lower engine down into place, line it up and put together. if you still stuggle, then no offence but i dont think you should be taking an engine out mate.
you should only have to take the box out and put them both up together when space is an issue which with a cvh in a mk4 it really is not
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
