my orion keeps cutting out
Old May 8, 2008 | 01:56 PM
sethgremlin's Avatar
sethgremlin
Default my orion keeps cutting out
hi i hope someone could help me, i have an orion lxi 1993 model, when i come to a stop or put the clutch in, every now and then it cuts out.
sometimes the revs move up and down by themselves too.
what could be causing this and is it cheap to fix?
thanks
Seth
Old May 8, 2008 | 02:18 PM
johnny99's Avatar
johnny99
Idle control valve, poss.
John
Old May 8, 2008 | 02:29 PM
sethgremlin
thanks i'll check it out.
Old May 8, 2008 | 03:09 PM
As said ISCV most likely, but also give the MAF a clean at the same time.
Old May 8, 2008 | 05:50 PM
instain's Avatar
instain
if its anything like my old 1 it runs fine just when you cone to stop and take your foot off the accelerator, if it is i got told ecu was on its way but dont quote me cause i just weight it in at that point
Old May 9, 2008 | 03:02 PM
sethgremlin
thanks, i got quotes for the parts, just need to find a cheap place to fit em.
Old May 9, 2008 | 05:53 PM
DIY easiest thing in the world to do.
Old May 12, 2008 | 02:09 PM
sethgremlin
heh not for me, although i do know a couple of people who might be able to help.
thank you
Old May 12, 2008 | 02:20 PM
A VERY easy job to do, more by feel than sight but still easy.
Old May 15, 2008 | 02:48 PM
sethgremlin
i'll have to get me a haines i think.
this car is a nice car other than the cutting out issue.
it only happens once its warmed up.
Old May 17, 2008 | 07:13 PM
dangerousscally's Avatar
dangerousscally
ive had the same symtons with ma s2 rst running mfi but only when it gets warm. i adjusted the tickover screw abit. it runs much better when of the accelrator
Old May 20, 2008 | 12:47 PM
sethgremlin
apparently my car is the cfi model so i have no icv or maf sensor. so what should i do?
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
cossirob
Sep 16, 2015 07:39 PM
