rst managment problem
Old May 2, 2008 | 04:15 PM
10th_racer's Avatar
10th_racer
Default rst managment problem
ok, so, its a turbo'd ka, on frst managment, not sure if its OFAB or OFAC, dont know anything about it managment wise really, but have found something suspicious.
its got a superchip on the ecu, but then has also got a remapable dastek unichip on it, but why on earth would something need both?
i was always under the impression that these unichips were just piggy back ecu's and if unplugged it the car would just return to running on the standard map, i tried unplugging the unichip earlier and it wouldnt run at all.
here are a couple of pics of what its like now, far from some of the neatest wiring in the world....
so how do i tell if its OFAB or OFAC? and why would it have 2 chips on it?
Old May 2, 2008 | 04:18 PM
DanCossie's Avatar
DanCossie
Post Whore
Need to get some clearer pics mate
and you need to take the ECU out and it will have it stamped on it
Old May 2, 2008 | 04:56 PM
jammy86's Avatar
jammy86
Which ECU is that? The RST one or the Ka one? most of the conversions still leave the Ka ecu in place.
JAmes.
Old May 2, 2008 | 05:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
Good lord, who installed that lot!
Unichip cant bypass boost limits so they often need a chip too. Which kind of nagates the point IMO.
Old May 2, 2008 | 05:21 PM
10th_racer's Avatar
10th_racer
right, i'v just got in touch with the guy at powercrazy motorsport that built the car and used it for over a year as his daily driver, when he built it it only had the superchip on it and made 220bhp, it was mapped by ahmed bayjoo, and was running 13.1 second quarters :O
however....he then sold it to a young lad, who fuked about with it a lot, and not in a good way, different filters, whanged the boost right up, and had the unichip put on it, which made it run like a bag of nails apparently, although its running better now its still not quite right, hence me delving deeper into it.
so, first things first, fucking the unichip off and having it mapped propperly.
stu you have a pm
JK12
33
Apr 26, 2021 12:09 PM
Chas
Oct 5, 2015 07:13 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
BRAM
Sep 8, 2015 07:11 AM
