2L ZETEC Gearbox Options?
Old Apr 20, 2008 | 03:26 PM
jasonb89's Avatar
jasonb89
Default 2L ZETEC Gearbox Options?
hi guys, im a new member here so hi to everyone. what im after is abit of information on gearbox option for my 2l zetec turbo that im doing. i inted to run 13" wheels (yes i did say 13"!) but want a box that will give me the right sort of ratios i need to get the power down with such small diameter wheels. or if there is a bolt on rwd box id also be interested in that as well. thanks in advance for any help you can give. cheers, Jace
Old Apr 20, 2008 | 05:21 PM
The T5 will go on the zetec, as ford helpfully kept the bolt pattern pretty much the same across thier engines.
Old Apr 22, 2008 | 09:19 PM
pdfbt40's Avatar
pdfbt40
Until the I4 Duratec HE......
Don't forget to fit a spigot bearing in the crank of the Zetec.
Old Apr 23, 2008 | 11:15 AM
jasonb89's Avatar
jasonb89
o right thats handy to know, would the rs turbo box with the LSD fit? also do you know where i can got hold of the gearbox ratios for the ford boxes?
Old Apr 24, 2008 | 06:15 PM
woolford's Avatar
woolford
Id go for the mtz75 with quaife diff as this will be very very strong
Old Apr 25, 2008 | 08:25 AM
pdfbt40's Avatar
pdfbt40
Any of the 4 Ford transverse boxes will fit (with the appropriate flywheel/clutch/starter):
BC >95
IB5 95>
MTX75 92>
MT285 02-05
as will longitudinal ones with the correct bellhousing/mainshaft.
Not all are the same though. For example the MTX has versions with rod gearchange and 2 different cable changers. Also the casings differ depending on car/engine it was fitted to (different bolt bosses for mounts, V6 engine). Also the gearbox front/bellhousing needs to match for starter motor position, late (blacktop) Zetec gearboxes have the starter behind and above the block.
Depending on the age, the best/easiest source for cluster and FD ratios is the Ford TIS. Pre '98, probably a Haynes manual.
TPM961
Jan 15, 2018 10:50 AM
focuspower
Sep 19, 2015 08:27 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
BRAM
Sep 8, 2015 07:11 AM
cossirob
Sep 3, 2015 09:17 PM
