What cps on ZVH
Old Apr 16, 2008 | 09:49 AM
Gregor's Avatar
Gregor
Default What cps on ZVH
Well... my efi conversion is almost at a halt
Can't get an rpm reading but my cps is giving 2.5-3 volts when cranking...
What cps are all the zvh owners here using? the zetec or the cvh???
thanx
Old Apr 16, 2008 | 10:42 AM
Bomber's Avatar
Bomber
What flywheel are you using?
Old Apr 16, 2008 | 12:14 PM
Rick's Avatar
Rick
is it using the edis module? It's not the CPS - they are all the same, if it's giving out 3v when crancking it's fine.
Old Apr 16, 2008 | 03:19 PM
Gregor's Avatar
Gregor
Using a cvh flywheel.
Got a cvh and a zetec sensor here and the cvh is longer....
Anyway, ain't using the edis module
Coil is directly driven by the ecu.
Old Apr 16, 2008 | 03:23 PM
Bomber's Avatar
Bomber
You need to match the sensor and bit the sensor fits into, to the flywheel you have.
Old Apr 16, 2008 | 03:28 PM
Gregor's Avatar
Gregor
Ok.. i get a voltage off both of them but the longer one seems to touch the flywheel just so the zetec one will be fitted...
But like Rick is saying.. when it's ginving 3 volts it shoul be ok and my problem is elsewhere.... thanks
Old Apr 18, 2008 | 11:01 AM
Rick's Avatar
Rick
The sensor casings are slightly different, but they all work the same - urs is fine by the sounds of it. What ECU are you using? Have you configured that correctly?
Old Apr 18, 2008 | 11:03 AM
Rick's Avatar
Rick
Looks like MegaS from your sig. Does it work on the stim? have you configured your trigger angles and wheel decoder? Are you getting anything at all?
Old Apr 18, 2008 | 02:16 PM
R6Franky's Avatar
R6Franky
I had this same thing bothering me lately. The OFAB CPS hits the back of the efi 220mm flywheel so I'm going to use the original one that was in the mondeo lump.
At first I didn't know if I was going to have to space the fiesta one out but since reading the posts on here other people seem to get by with the zetec one. Still a bit concerned as to whether it will fire up first time though.
Old Apr 19, 2008 | 05:05 AM
Gregor's Avatar
Gregor
Yeps the Megasquirt 1 v3...
Trigger angles and wheel decoder are all looking fine.
Thing is i don't have a stim
But a mate of mine does and is coming over next weekend so we'll see then...
Thanks
Old Apr 19, 2008 | 05:09 AM
Gregor's Avatar
Gregor
Only thing i'n not getting is rpm reading in megatune...
iat,clt,afr,ignition timing all is working fine....
Old Apr 19, 2008 | 08:51 AM
mentalasanything's Avatar
mentalasanything
I didn't even realise you could directly drive coil packs from a MegaSquirt, I thought that you still needed to use the EDIS module!
A question nobody has asked yet, does the car run?
Old Apr 19, 2008 | 12:35 PM
Gregor's Avatar
Gregor
Yess, if you use direct coil drivers you don't need the edis-module.
Can't run an efi car whithout cps signal..... so no..it's not running
Old Apr 19, 2008 | 01:55 PM
mentalasanything
I know you can't run an efi car whithout cps signal. All you said was....
thanx
The car can run without an RPM signal out of the ECU to your tacho for example cant it, just not without a CPS signal.
Anyway,
Do you have it wired like this?
www.extraefi.co.uk
Do you have the CPS wired the correct way round and the shield in the correct pin?
I was sure they were both the same CPS but I'd only ever heard of people using the CVH CPS with the zetec 1.8 flywheel or CVH crank pulley.
If you'd used the EDIS module you could have had a better chance of troubleshooting it. The EDIS module can run the ignition without an ECU in a very basic "Limp home mode" so you'd know if your sensor and pickups were fine.
Other than that stick it on a stim and see what you get back!
Lee
Old Apr 19, 2008 | 02:04 PM
mentalasanything
look here too https://passionford.com/forum/technical-help-q-and-a/182711-cps-cos.html
Old Apr 19, 2008 | 06:00 PM
Gregor's Avatar
Gregor
Hej mate,
i see i didn't explain the whole story
Anyway, i sorted the problem..
I notices today that when i crank it all meters go to zero in megatune....
Hooked up a volt meter to the ms and when i crank it i got no voltage on it....
I did the wiring according to the schedule i got with the ms.
So the yellow powerlead when it's on contact powers everything but when i crank it there's no power on this...
Schould i connect the cranking puls lead as well to the ms so i got power to it when i'm cranking?
Stupid i never saw this before..
Hooked up the MS to a constant powerlead and got a nice 300 rpm when cranking
Old Apr 19, 2008 | 07:19 PM
mentalasanything
Hej mate,
Good to hear mate, glad it's working now!
Old Apr 20, 2008 | 04:52 AM
Gregor's Avatar
Gregor
Me too, now just mapping it and away we go
DixieTheKid
11
Jun 6, 2020 11:20 AM
mk1turboestate
Dec 2, 2015 08:31 PM
davidfordrs
Sep 21, 2015 04:23 AM
biggiejody
Sep 19, 2015 10:25 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
