Gasket
Apr 13, 2008 | 10:48 AM
Apr 13, 2008 | 11:02 AM
looks like a 2wd thermostat housing to me
Apr 13, 2008 | 11:57 AM
I'm also thinking of a thermostat housing gasket,but the 4x4 has 3 bolts,dunno how it's with the 2wd
Apr 13, 2008 | 06:49 PM
As said defo 2wd thermostat housing gasket.
Apr 13, 2008 | 07:11 PM
Ok thanks,so this will not fit the 4x4 housing??
Gasket was bought in a complete 4x4 engine set
Apr 13, 2008 | 07:13 PM
somtimes they come with both iirc
Apr 13, 2008 | 10:39 PM
The 4x4's use a rubber 'o' ring which sits in a recess where the thermostat housing sits on the head. The gasket shown is a thermostat housing gasket from a 2wd so will not be used on a fourbie.
Apr 14, 2008 | 05:36 AM
As there is so little difference in the way of gaskets between 2 and 4wd they probably just package the lot in every set.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 23, 2015 06:28 AM
pie-face
Sep 15, 2015 10:43 AM
