Top end knocking sound
Old Apr 2, 2008 | 04:33 PM
S2Steve's Avatar
S2Steve
Default Top end knocking sound
I get what i think/hope is not a knock as i let off the throttle from the top of my cvh, any ideas what it could be? The head has only done about 3k and the cam was fitted as a kit about 1500miles ago and run in properly.
Old Apr 2, 2008 | 04:40 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Kent cam kit??
Old Apr 2, 2008 | 04:51 PM
S2Steve's Avatar
S2Steve
Yep. cvh35
Old Apr 2, 2008 | 04:53 PM
Christian and Beccy
#1 in Spelling Club
As much as I am loathed to say it, it's had a lobe or two for lunch.
Old Apr 2, 2008 | 04:54 PM
Christian and Beccy
#1 in Spelling Club
I think Kent expect you to change your cam each time you fill up with fuel. They should paint it yellow and call it a service item.
Piper cams for CVH aren't much better.
Newman are the best of whats available. Take that as words of experience, I have been through all this.
Old Apr 2, 2008 | 04:58 PM
S2Steve's Avatar
S2Steve
SO its lasted about 1500 miles, does it not have a guarantee at all? It still goes like stink though and drives perfectly...
Old Apr 2, 2008 | 04:59 PM
Christian and Beccy
#1 in Spelling Club
I might be wrong about it, but I have had one go within 500 miles and know of 3 others that did the same around the same time that were unrelated to us.
Old Apr 2, 2008 | 05:01 PM
S2Steve's Avatar
S2Steve
Any other symptoms i can look out for?
Old Apr 2, 2008 | 05:04 PM
Christian and Beccy
#1 in Spelling Club
Not really. Rocker cover off, whip the lifters out and take a look is the best bet.
Old Apr 2, 2008 | 08:27 PM
juffer's Avatar
juffer
if it was cam or followers it would tap all the time! does it knock as you accelerate aswell?
juff
Old Apr 2, 2008 | 10:08 PM
Christian and Beccy
#1 in Spelling Club
Not necessarily, it would tap less as oil pressure increases, and more as oil pressure decreases (like when you lift the throttle)
Old Apr 3, 2008 | 10:37 AM
Zetecfiesta's Avatar
Zetecfiesta
well thats a good bit of advice! was looking at kent and piper, think i will go for newman now! which cam kit should i get though im really confused by all the numbers and lift and spec! im building engine so but its just normal build nothing wild, head work propbably but on standard turbo.
Old Apr 3, 2008 | 10:57 AM
Christian and Beccy
#1 in Spelling Club
Newman only do one off-the-shelf CVH cam and thats ideal for you. It is solid lifter though, so 10 times more difficult to fit and set up than a normal cam, but with very little chance of problems.
Old Apr 3, 2008 | 11:00 AM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Mine taps at idle, and if i raise the revs the tapping noise goes away. Any idea what this would be?
Old Apr 3, 2008 | 11:25 AM
S2Steve's Avatar
S2Steve
To be honest mine doesn't do it all the time. Its mainly when cold and idling, after that its fine but a little noisey at warm idle, but aren't all cvh's
Old Apr 3, 2008 | 12:02 PM
Christian and Beccy
#1 in Spelling Club
You sound like you're trying to convince yourself that there isn't a problem!! Maybe there isn't. Get out there and have a look, it's really not that hard a job.
Old Apr 3, 2008 | 04:01 PM
S2Steve's Avatar
S2Steve
haha yeah i am! Its cuz i spent all my money getting it rebuilt and can't afford to do it all again! I also would not know what i'm doing taking it apart and setting it back up again
Old Apr 3, 2008 | 05:18 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
mine make no noise... no idea what the cam is but it was put in by Tony from Turbosystems
IAN RS2k
Aug 18, 2015 07:51 PM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
Bezzy41
Aug 3, 2015 10:31 AM
