Corner weighting
Old Mar 30, 2008 | 07:57 PM
rstdave's Avatar
rstdave
Default Corner weighting
Just wondering what is actually involved in corner weighting a car and how it's done???? And the difference it's likely to make to the handling?
Cheers.
Old Mar 30, 2008 | 09:25 PM
Red16's Avatar
Red16
as far as im aware... your car is put on 4 scales, then the coilovers are adjusted until the readingsn the scales are as equal as possible, not always possible due to front/rear weight differences, but as close as possible.
have a read of this
http://www.northamptonmotorsport.com/default.asp?id=20
Old Mar 31, 2008 | 03:34 PM
rstdave's Avatar
rstdave
Cool, cheers that's the sort of info i needed!!
Old Mar 31, 2008 | 03:36 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Can this be done on a road car? Benni.
Old Mar 31, 2008 | 03:38 PM
rsnissan's Avatar
rsnissan
any car with coilovers
Old Mar 31, 2008 | 03:39 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
You can corner weight anything, but you can only adjust it if you have adjustable spring platforms like on a coilover, or I suppose you could use shims under the springs on a normal shock to change it, but a lot of fucking about
vroomtshh's Avatar
vroomtshh
And make sure you get it done with the driver sitting in the car!
Old Mar 31, 2008 | 04:39 PM
Doesn't need coilovers, any car can be done by adding weight to equalise all four corners, like the radicals were doing today at snetty!!
wowk
Mar 30, 2021 07:49 PM
Mark RS
Mar 5, 2021 06:08 PM
gingeRS
17
Oct 2, 2015 09:42 AM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
