Cyilnder head skiming, How much can go?
Old Mar 29, 2008 | 06:56 PM
david_xr's Avatar
david_xr
Default Cyilnder head skiming, How much can go?
heyy, im new on here few of my mates said it be good idea to ask on here,
neway my plan is to skim the head on a N/A cvh (xr2i) im jus unsure how much i can take off, has anyone done this before if they have how much did u take off?
any help would be great
Old Mar 29, 2008 | 09:12 PM
flashpoint's Avatar
flashpoint
I guess your skimming the head for reasoners other than just making sure is flat?
as I've only relay played around with turbo cvh's and skimming the head is only done as a last resort as any removal of head material will up the comp ratio, it's hard to say how much you can safely remove? i would Guess about 1mm ? i could be wrong...? would would have to work out the comp ration with such a reduction as it could become undesirable high...eek
Steve
Old Mar 29, 2008 | 09:47 PM
craig rs's Avatar
craig rs
it really depends, when im skimming a head i dont like to go more than .75mm, i just skim small amounts at a time i.e .1mm untill all the face cleans up
Old Mar 29, 2008 | 10:01 PM
blan77's Avatar
blan77
the maximum i will machine off a head to stay safe is 1mm , as above tho get them to take 0.1mm cuts at a time ,until its clean .
Old Mar 30, 2008 | 12:26 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
at my old place, we used to take off .020", any more than that and we'd fit a shim. not that thats all you can take off, it was just like a safe figure.
as long as there's sufficient clearance between your valves and pistons, your head face and seats and provided the CR isn't over the top, there's no real 'limit'.
Old Mar 30, 2008 | 12:31 AM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
55 thou
Old Mar 30, 2008 | 04:19 PM
david_xr's Avatar
david_xr
thanks so far, the only reason for skiming it is id just like to up the comp ratio, the curent ratio (standard) is 9:75:1, alot of you have said 1mm is this eqaul to 10thou? not good at maths lol, and 55thou that seems alot is that gonna work?
Old Mar 30, 2008 | 04:39 PM
flashpoint's Avatar
flashpoint
Originally Posted by david_xr
thanks so far, the only reason for skimming it is id just like to up the comp ratio, the current ratio (standard) is 9:75:1, alot of you have said 1mm is this eqaul to 10thou? not good at maths lol, and 55thou that seems alot is that gonna work?
well taking 1mm of the head will up the comp ratio. depending which style head you start off with. you will have different comp results... what sort of comp are you affter...?
Old Mar 30, 2008 | 10:27 PM
Turbo Zetec
Engine Machinist
1mm is not equal to 10 thou, 1mm is 39 thou.
Old Apr 2, 2008 | 02:27 PM
Aaroncast's Avatar
Aaroncast
------look on a feeler gauge if your confused!!!!!!!!!!!!!!!!!
Old Apr 3, 2008 | 06:42 AM
It's actually 1 thou = 39.370078mm
Old Apr 3, 2008 | 01:20 PM
LEE-RS's Avatar
LEE-RS
Custom
1.27mm is 50 thou i had a xr3i head skimmed this much it went very well
Old Apr 3, 2008 | 11:35 PM
Turbo Zetec
Engine Machinist
now i want you to take a good look at what you've just written...
serves you right for trying to be a smart arse
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
