Electrical zetec issue
Old Mar 25, 2008 | 04:32 PM
pacman's Avatar
pacman
Default Electrical zetec issue
Hi All
Run into a bit of a dead stop with this one, if anyone can shed any light it would be appreciated.
CAR: Ford Escort 1.8 Zetec Si 1998
PROBLEM:
While on the motorway in the car all the dash lights came on as if it stalled, still smooth, proceeded with hazards on as speed dropped to make my way over to the hard shoulder, as i moved across it became more jerky until i got across and the car eventually stopped. Now the car will not start.
CHECKED:
Cambelt fine, cams fine, battery fine, inertia switch ok, ignition switch ok. There is NO prime when the key turns for the fuel pump and the relay for the Dip beam (r8) is clicking away merrily, which stops when removed also the fuse for the front foglights has blown. All lights were fine though.
SO FAR:
Ok, i was thinking fuel pump obviously as i am getting spark etc and turns over readily but no fuel. But and this is the confusing thing, with no keys in the ignition battery shows 12.4v turn the key so dash lights are on 8.4v, turn key off back to 12.4v. Could this be an immobiliser issue that is incorporated into the fuel system thus making it look like the fuel pump. I am aware the PATS is the system linked to the key where if that fails to read the key it will turn over but not fire, any chance it's this.
Also why would the electrical circuits play up and break the relay and blow the fuse? Any suggestions very much appreciated. I'm not to hot on auto electrics as you can probably tell.
Thanks all
Dave
Old Mar 25, 2008 | 04:49 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
First thing I'd do is check the top of the fuse box for water ingress or any loose/damaged wiring. If you pop the cover for the fuses off then remove that lower panel (half dozen screws) you'll be able to release the metal clip and swing it down.
If that's ok then I can't think of owt else.
Old Mar 25, 2008 | 05:13 PM
pacman's Avatar
pacman
Cheers leeeroy.
Already done my friend, it's all hanging down as it stands now. No moisture at all mate, Had a few i've done though that has been that. Funnily enough all been xr3i variants thinking about it.
Thanks for the reply
Old Mar 26, 2008 | 06:44 AM
Could well be the PATS and moisture, had this once on a mondy when I spilt some water(lots) around the facia area, but dried out the pats and been fine ever since.
JK12
33
Apr 26, 2021 12:09 PM
Kam B
Sep 24, 2015 10:40 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
talon1
Sep 15, 2015 10:27 AM
BRAM
Sep 8, 2015 07:11 AM
