Can you re-use a.....
Old Mar 17, 2008 | 11:27 AM
picky775's Avatar
picky775
Default Can you re-use a.....
Felpro head gasket for a cvh its been on car 2 days??????
Old Mar 17, 2008 | 11:30 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I wouoldn't use one in the first place, let alone RE-use it!!
Is it a 1600? If so, go buy a standard one.
Old Mar 17, 2008 | 11:37 AM
picky775's Avatar
picky775
yes its a 1.6 turbo ive had felpro gaskets before and not one has let me down were as ford gaskets and aftermarket ones have whats so bad about them??
Old Mar 17, 2008 | 11:56 AM
Christian and Beccy
#1 in Spelling Club
I'm still running OE Ford (Payen) on mine, as most of the big power RST's are. If you've had OE gaskets let you down then it will be for another reason, not the gasket.
Old Mar 17, 2008 | 12:09 PM
picky775's Avatar
picky775
I will go get a ford one again then coz head has to come back offcheers
Old Mar 17, 2008 | 12:16 PM
aurallis's Avatar
aurallis
is it worth it just replace it mate
Old Mar 17, 2008 | 02:23 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I had problems with the Felpro gaskets years ago it looked like it overhung the bore when it went, it burnt out between the cylinders and fucked the head and block.
Old Mar 17, 2008 | 02:59 PM
Christian and Beccy
#1 in Spelling Club
Originally Posted by EsCosRacer
same as asking if u should reuse a condom - u can but results are to be foreseen
That's an excellent comparison.
You could rinse it out, but as you say, I wouldn't want to bet my balls on it.
Old Mar 17, 2008 | 03:13 PM
picky775's Avatar
picky775
Obviously never heard of the geronimo(the one you wash)
Old Mar 17, 2008 | 03:15 PM
picky775's Avatar
picky775
geronimooooooooooooooooooooo
i bet dennis @ tdi has heard of it.....thats how he was made by accident
pmsl
Old Mar 17, 2008 | 05:01 PM
DaveZS's Avatar
DaveZS
Better use my strong hand
AFPMSL
NEILNATO
Mar 28, 2020 02:19 PM
cozzy jeff
Jan 4, 2014 03:43 PM
s1turboman
12
Mar 22, 2009 12:15 AM
fraser9764
Mar 17, 2009 10:43 AM
SillyFezzaMk1
Feb 10, 2008 03:51 PM
