whats the max boost standard rods....
Old Mar 13, 2008 | 09:14 PM
picky775's Avatar
picky775
Default whats the max boost standard rods....
Whats the max boost standard 1.6 cvh turbo rods can take????? Ive got cosworth racing pistons but standard rods.
Old Mar 13, 2008 | 09:15 PM
bonus_boy's Avatar
bonus_boy
i think nick from PF is running 20/25psi on standard pistons and rods so...
Old Mar 13, 2008 | 09:25 PM
kiddie's Avatar
kiddie
I ran 26psi on standard rods, no issues in the 15k I put on the engine
picky775's Avatar
picky775
Im runnin 18psi at the mo but dont know if i turn the boost up when i put my bigger injectors in its going to blow itcomp ratio is 7.95.1 if that helps???
Old Mar 13, 2008 | 09:31 PM
kiddie's Avatar
kiddie
This was spec, engine was rebuilt before I bought it so can't tell you the comp is sorry
Power engineering Low comp 1600cc CVH, +0.5 oversized Mahle Pistons, Lightened and balanced, with machined flywheel, ARP big end bolts
Power engineering stage 3 big valve head +1.5mm oversized inlet and +1.0mm exhaust valves; gas flowed, ported and polished, with matching inlet
Piper 285T Cam
Piper Vernier pulley
Double valve springs
Anti Pump lifters
Genuine Ford head gasket and head bolts
Stage 3 oil cooled Cosworth spec hybrid turbo 55 trim wheel with a 48-exhaust housing
-31 Actuator
3 Way Bleed Valve
Power Engineering Chip
Rev limiter raised to 7200rpm
Aquamist MF2 5th Injector using Cosworth green injector
Baileys DV26 dump valve
K&N Induction filter
Pace large front mounted intercooler with reverse charge carrier
Samco and Roose Motorsport silicon hoses
NGK 9 plugs
Ford Motorsport leads
Cosworth Fuel pump
Deflex poly bush kit
Baileys Header-tank and oil separator
Fusion Fabrication, cam cover, heater box, catch tank, servo cover,
Chrome Inlet, Rocker cover, and other engine detailing
Old Mar 13, 2008 | 09:34 PM
crazycage's Avatar
crazycage
fuck me mate 18psi on blues i would be VERY carefull i maxed mine out @ 6psi
Old Mar 13, 2008 | 09:39 PM
Nick-T's Avatar
Nick-T
19psi and at one point we were revving to 7700rpm!
Old Mar 13, 2008 | 09:40 PM
picky775's Avatar
picky775
I know mate i think thats what the det noise is,got a set of light greens the other day but dont know what hp there good for.any ideas??
Old Mar 13, 2008 | 09:41 PM
picky775's Avatar
picky775
Is the engine still alive????
Old Mar 13, 2008 | 09:43 PM
crazycage's Avatar
crazycage
no it throw a rod but it wasnt boost it was the revs that killed it mate
Old Mar 13, 2008 | 09:44 PM
crazycage's Avatar
crazycage
no mate but the blues are only good for 170 max
Old Mar 13, 2008 | 09:45 PM
crazycage's Avatar
crazycage
what sort of power was that making then??
Old Mar 13, 2008 | 09:47 PM
Nick-T's Avatar
Nick-T
Revs did indirectly cause it to break yes, but it was technically me being a chump that killed it!
I 'may' have slightly over revved it whilst on a spirited drive....
Old Mar 13, 2008 | 09:50 PM
crazycage's Avatar
crazycage
i no i remember jamie telling me you held it in 3rd a bit to long i was gutted when it went bang you got great power out of it.
Old Mar 13, 2008 | 09:55 PM
Nick-T's Avatar
Nick-T
The current one is doing even more! It made 265bhp on the limiter at 19.5psi!
Old Mar 13, 2008 | 09:59 PM
crazycage's Avatar
crazycage
cool mate he got mine upto just over 261@16psi, he's in the middle of my new 2.1 st170 turbo lump cant wait to see what he gets out of that
ps if i remember correct it was only a rod bolt that faild
Old Mar 13, 2008 | 10:02 PM
Nick-T's Avatar
Nick-T
Should be interesting!
What are you putting that in?
Old Mar 13, 2008 | 10:07 PM
kiddie's Avatar
kiddie
just under 246bhp 245.? sold the graph with the car
Old Mar 13, 2008 | 10:09 PM
crazycage's Avatar
crazycage
Smile
fiesta turbo
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
