lc-1 wideband question....
is the analog output number 1 (0.10v-1.10v) the same scale of a standard narrowband ?? ie if i replaced a narrowband with wideband and used the output 1 connected to the signal wire to ecu so lc-1 wideband will be supplying ecu with readings for closed loop, is that right?????
cant write above to sound right but hopefully you will get me lol
You program it to whatever u like with the programer software, it has 2 analogue outputs, which u can set to anything u like. One of the software presets is narrow band simulation.
Carlsworth
Aug 3, 2006 12:29 AM
Jim Galbally
Mar 10, 2006 12:17 AM
Jim Galbally
Mar 9, 2006 09:49 PM
