How do you remove the steering wheel?
Old Jan 30, 2004 | 01:07 PM
MJC's Avatar
MJC
Default How do you remove the steering wheel?
This may seem like a stupid question but how do you remove the steering wheel from a MKIII escort?
I've removed one before. Undo the centre nut on the steering wheel and then just down to shear force. Is this the right way and only way?
I've tried to remove the one on my new car and it won't budge. Is there a tool you can buy to assist or is there another way that I don't know about?
Help need, its doing my in
Old Jan 30, 2004 | 01:18 PM
cossymad's Avatar
cossymad
Brut force -or a hub-puller can be bought
Old Jan 30, 2004 | 02:01 PM
MJC's Avatar
MJC
Default Hub puller?
How much are hub pullers roughly. Can I get them at my local Halfords?
Cheers, MIKE
Old Jan 30, 2004 | 02:07 PM
cossymad's Avatar
cossymad
F*ck knows!
Probably, I always pull 'em off.
Loosen the nut, but leave it on and yank for your life.
Old Jan 30, 2004 | 02:19 PM
MJC's Avatar
MJC
Default Steering wheel
I must be getting weak with my old age. I'm only 22, god help me.....
I fitted it to my previous S1 and did the change over within 5mins. Can't do it to save my life this time
Old Jan 30, 2004 | 02:53 PM
cossymad's Avatar
cossymad
smash it.
Old Jan 30, 2004 | 03:43 PM
MJC's Avatar
MJC
Originally Posted by cossymad
smash it.
I thought I was going to break it, thats why I walked away and thought I would ask on here first.
Wish me luck, its going to be a nightmare
Old Jan 30, 2004 | 05:55 PM
JesseT's Avatar
JesseT
Just don't forget to take off the steering lock first. Othervise it should come out easy.
Old Jan 30, 2004 | 06:14 PM
IANS2RST's Avatar
IANS2RST
as above u need the keys in the ignition and at least on the 1st position., if you don't you will break it
Old Jan 30, 2004 | 09:54 PM
defo the steering lock, catches a lot of people out, not me of course.........
Anyway, leave the nut on a couple of threads and persuade it off using a soft mallet (be carfule not to leave marks on the wheel). This is how i did it.
Old Jan 30, 2004 | 10:39 PM
sm's Avatar
sm
keys in ignition so steering lock is off and just bang with ur fist on ethier side of the wheel till it lossens and then pull it off, works every time
cheers sm
Old Jan 30, 2004 | 10:58 PM
DannyC's Avatar
DannyC
Ya soft bastard just pull it off!
Fuckin southern fairy
Old Jan 31, 2004 | 02:12 PM
MJC's Avatar
MJC
Default Southern fairy...!
Don't mess with the southern fairy you northern monkey
I had the ignition on when I was attemptin it but didn't want to budge. I will have another go today and will let you all know how I get on.
I best not break anything
Old Feb 1, 2004 | 04:23 PM
MJC's Avatar
MJC
Default Steering wheel.
Thanks to everyone who replied
I've managed to remove the steering wheel today. Still don't know how it managed to put up such a good fight! but after a little I came through victorious
JoeyBoyden
Jan 4, 2024 02:36 PM
YODI
Aug 30, 2015 01:12 PM
RockinRein
Aug 19, 2015 07:08 PM
Roosie
Aug 19, 2015 11:52 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
