Embarassingly simple turbo question
Old Feb 28, 2008 | 12:14 AM
Char1ie's Avatar
Char1ie
Default Embarassingly simple turbo question
If I adjust the length of the actuator shaft will I change the boost? T3 on 2WD Sapphire btw.
Thanks all,
Charlie
Old Feb 28, 2008 | 12:28 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes, shortening the rod to add more preload, will increase the boost generally (assuming its not limited in some other way)
Old Feb 28, 2008 | 12:38 AM
Char1ie's Avatar
Char1ie
OK. Thanks. I just got back my housing with a new wastegate shaft and fitted it. I think the lever on the wastegate must be in a slightly different position. I couldn't get the actuator shaft back onto the lever and had to adjust it's length - I added two turns of length.
The car is a race car, so I won't be able to use it until I'm at the track again. Is it best to start with the actuator shaft longer and after a couple of runs shorten it to get to the correct boost?
I don't want the car to run too much boost.
Thanks,
Charlie
Old Feb 28, 2008 | 12:46 AM
Chip's Avatar
Chip
Too long is safer than too short if you are worried about the boost going too high.
Old Feb 28, 2008 | 08:14 AM
Char1ie's Avatar
Char1ie
Great, thanks.
Charlie
Old Feb 28, 2008 | 12:44 PM
Char1ie's Avatar
Char1ie
I've just been speaking to CR Turbos, the company that modified my wastegate shaft. His advice for refitting is that the actuator shaft hole should be short of the lever arm connection by the width of the hole, so that when you pull the shaft to fit it to the arm you only need to pull it 4mm or so. And some common sense measurement - +/- one turn of the actuator shaft = +/- 1lb of boost.
Charlie
Old Feb 28, 2008 | 12:46 PM
Chip's Avatar
Chip
Yes that sounds about correct for how most people set their actuator, so if you go longer than that (ie less than a shaft hole width) then you will get less boost.
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
borboyous
Aug 22, 2015 11:17 AM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
