CARNT FIND BIGGER BRAKES 4 ST220
Old Feb 16, 2008 | 09:31 PM
m_nettleship's Avatar
m_nettleship
Default CARNT FIND BIGGER BRAKES 4 ST220
Any no anywere, or will i have to make some up,, using diffreent bit etc.
Old Feb 16, 2008 | 10:02 PM
It's Czech Mate's Avatar
It's Czech Mate
ask Dojj
Pumabuild do bigger ones
Old Feb 17, 2008 | 02:01 AM
jonnyboy's Avatar
jonnyboy
http://www.hispecbrake.co.uk/Convers...0360%20Mon.htm
dont really rate them but that is about it
or i got these knocked up for my old mondy.378mm x 36mm ap discs with 4 pot brembo but needs at least 19's
Old Feb 17, 2008 | 08:22 AM
dojj's Avatar
dojj
Resident Wrestling Legend
reyland
but you will need to drop him off a hub and botom ball joint and track rod end to work out clearances, plus a rim to fit it all under
you can try others but i'd recommend not to
there are detailed posts regarding brake upgrades if you wish to search them out, just put in "dojj" and "pumabuild" nto google and look at the resluts
Old Feb 17, 2008 | 09:33 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
As already mentioned.... I can make up an AP kit but either need a hub& wheel to work with OR drop off the car for 7-10 days and drive away with the job done! Do have a loan car that can be used too.
Old Feb 17, 2008 | 10:26 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
martin, we featured a st220 last year, he had given ap his car to use as development for a brake kit.
iirc they use a 380mm disc and fit behind the std rim.
so ap should do an off the shelf kit, or at least be able to knock one up
HTH
Old Feb 17, 2008 | 10:35 AM
Steven_RW's Avatar
Steven_RW
Dan - I think there is very little chance a 380mm disc is going to fit behind a standard 18 inch rim, surely it doesnt have the clearance?
My 356mm discs n aps only JUUUST fit under my 18's on my m3.
I think brakes are the one key area where a mondy st220 falls down (my dad has one) and think a brake upgrade kit would really really help the car
Old Feb 17, 2008 | 11:42 AM
steve7786's Avatar
steve7786
http://www.apracing.com/info/product...1065_1652_1045
Old Feb 17, 2008 | 11:49 AM
Martin-Hadland
Originally Posted by steve7786
http://www.apracing.com/info/products.asp?product=Ford%2D+Mondeo+ST220+%2D+Fron t+4+Piston+kit+CP5200%2D1065_1652_1045
That kit is Ł1458 plus VAT, He could have 362mm 6 pots for that!!
Old Feb 17, 2008 | 11:56 AM
steve7786's Avatar
steve7786
I know which i'd sooner have then
Highly recommend Reyland for getting brakes made up after sorting mine
Old Feb 17, 2008 | 07:40 PM
dojj's Avatar
dojj
depends on what the loan car's availability is but if it's to be used to go home and then back to you again with not much else then i'm up this saturday if it's free
Old Feb 17, 2008 | 08:02 PM
Martin-Hadland
It's this little gem, it would be available this coming Saturday onwards.
As long as your insurance covers it then you are welcome to use it.
Old Feb 18, 2008 | 05:41 PM
m_nettleship
wow Thanks ,, i will read through this.
Old Feb 18, 2008 | 05:50 PM
m_nettleship
martin tell me more,, yes i could drop moter off!!!
Car is running 246bhp with 75bhp Nos. Brakes are Shocking.
Thanks 4 Help all.
Old Feb 18, 2008 | 05:55 PM
Martin-Hadland
Originally Posted by m_nettleship
martin tell me more,, .
Thanks 4 Help all.
What more do you want to know?
Old Feb 18, 2008 | 06:53 PM
dojj's Avatar
dojj
unfortunatly martin the insruance certificate is still in the post after i moved so the addresses are different
but saturday is a deal, even if i don't have the certificate and can't drop the car off, soemthing will get sorted, i might even use the van......
Old Feb 18, 2008 | 07:09 PM
Martin-Hadland
Saturday is cool
Old Feb 18, 2008 | 07:13 PM
m_nettleship
Wat do you have on offer,, 4 me. I mean Price wise, etc. pm me if you can,, or i could call you tomoz morning??? pm me mate please.
Old Feb 19, 2008 | 12:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
just checked, and the ones i was on about were 330's
my bad
Old Feb 19, 2008 | 04:46 PM
xr-stu's Avatar
xr-stu
my stepdad runs a 330mm baer setup on his ST24 which was around Ł600 imported from america. i would imagine they do a similar setup for the MK3/ST220 or its yank equivelent.
his fit under ST200 rims with a 5mm spacer.
Old Feb 20, 2008 | 08:48 PM
m_nettleship
any more info xr stu ,,, website etc
Old Feb 22, 2008 | 05:58 PM
dojj's Avatar
dojj
i'll drop by martins tomorrow and see what's what
i'll take my camera just in case there is uber cool non secretive stuff i can picture take and post up too
malkiemac3579
Jul 14, 2017 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
turbobill
Aug 9, 2015 05:21 PM
blakey100
Aug 4, 2015 08:17 PM
