How long would an engine run with no oil pressure ?
*** Sierra RS Custard ***
I would say a LOT longer than you think if you mean a basic engine (ie not some turbo nutter bastard thing), ie minutes at least that it would still actually run, potentially even hours.
BUT the damage would be done in a matter of seconds that would then kill the engine even if you got pressure back.
Originally Posted by KSA-Cossie
But it would fuck the shells in seconds though ?
This would fuck the rods, bearings, block, crank
Its BAD news if you have no oil pressure under load for more than a couple of seconds (its not instant as the oil is still on the crank at the time the pressure stops).
I remember reading an old fast ford iirc where thieves stole a s1 and drained the oil then 7 miles later it siezed.
why did they steal it then drain the oil? seems a bid daft?!
Possibly to see what would happen, or possibly they drained it by whacking the sump on something, thats how I last drained my oil without meaning to on a car!
Sod wacking it, surely you would check first after thumping the underneath so hard
In my case I did check, and had cracked the sump, so I turned it off BEFORE it lost oil pressure, as I cared about the car.
In the case of a stolen car though, why would they care?
To make money out of the car they just stolen?
Once the oil light has flashed on the damage indeed has been done, but surely the car if stopped and shut down immediately and the problem rectified the engine should still see many many more miles???
Resident Wrestling Legend
FROM PERSONALL EXPERIENCE!!!!!
my car did approxamatly 55 miles with absolutly 0 oil pressures as the bolt came off the cog which supplied the drive to the oil pump on the 24V lump
and that was pootling about
the crank was survived this ordeal but most of the bearings were fubar, so i'm glad i didn't drive it up the motorway
all the while i was thinking that i hadn't connected the oil pressure gauge up correctly
Ban[B][/B]ned
Benni.
mine idled and drove in and out the garage several times with zilcho oil pressure and there were no marks of any kind on the bearings/crank
escort mk4 cossy 4x4
central group at santapod have done a blow up a banger for the last few years,ie old metro,drain the oil,full revs,and guess how long it lasts,after 9 seconds it threw a rod out the block.
My first engine blow up, was so pissed off a kept it going for about 2 miles till it would'nt go any further. welded the shells to the crank and just about every nut and bolt in the bottom end was fucked .
Baby Cheesus
when we got rid of the drift shitter i had the engine running up to temp, and after several big handfulls of gravel down the inlet it started to run a bit rough, so i drained the water and oil, it ran for a good 10 mins at part throttle before it siezed lol
i was hoping for a more spectacular scenario, but it just stopped lol
i done 120 miles on a newly built engine and it popped a half moon seal(oil everywhere),fixed that and noticed the oil pressure light flicker(they come on at 6)looked at gauge and was 5-6,was truelly gutted,drove to the garage,stripped it and swarf in the oil,crank was fine,new shells,pump and drive and its been fine this time
just like they used to do at the middx owners club show a few years back
a fiesta lasted more than 2 minutes
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
