S8 owner Last firmware needed
Old Jan 13, 2008 | 09:54 AM
july1's Avatar
july1
Default S8 owner Last firmware needed
Hi everyone!
I've just purchased a second hand S8 ECU
But when I try to establish the communication I get a message telling me that I need to upgrade the ECU
I sent an e-mail to SECS but as Simon seems to have stopped is business I was wondering if anyone could have saved this firmware and could send it by email..
My software version is 8021-x/100
The hardware version is H/W: 15400-COSV05
The ECU Software version is S/W: S8ECU-8015-F
I guess I need an ECU software version S8ECU–8021-x
I can do nothing else
Thanks
Old Jan 13, 2008 | 11:03 AM
july1's Avatar
july1
The file should be S8UP8021.ECU
Old Jan 14, 2008 | 01:30 PM
mikedaf2's Avatar
mikedaf2
i have software version 8021-103 dont know if this is the one you want.
Old Jan 14, 2008 | 04:58 PM
july1's Avatar
july1
I'm in touch with Simon so it should be fine soon.
Many thanks for your reply
Old Jan 21, 2008 | 09:34 PM
kjc300's Avatar
kjc300
Off the top of my head I'm not sure what my HARDWARE version is, I may go out and check in a mo.
pm me your email and Ill send you the 8019 software, install that (delete the other S8 file in C: drive saving any maps you have somewhere else first!!!) then you just have to install this software on the comp and do the 'ecu update'
Always save your maps somewhere else, as an ecu update can corrupt a map (well I had it once, not worth the risk!!)
Old Jan 21, 2008 | 09:35 PM
kjc300's Avatar
kjc300
Oh and this version doesn't work on xp
Old Jan 21, 2008 | 09:44 PM
july1's Avatar
july1
Ok fine
I sent my email through pm
I'll wait to know your hardware version before trying to upgrade to avoid more problems
Many thanks for your help
TomPengelly
13
Aug 22, 2015 06:38 PM
borboyous
Aug 22, 2015 11:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
bassboy
Aug 8, 2015 10:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
