dizzy timing t34 escos
Old Dec 28, 2007 | 05:33 PM
runty176's Avatar
runty176
Default dizzy timing t34 escos
hi - the dizzy has been moved on my t34 escos . should i strobe it ? if so what to ?
before i get it set up .
t4 , running greys
thanks
Old Dec 28, 2007 | 05:41 PM
I thought the T34 ones used a weber marelli set up(ecu).
In which case it is set, just make sure all is aligned correctly especially the phase sensor.
Old Dec 28, 2007 | 06:11 PM
runty176's Avatar
runty176
yep everything is timed up and the rotor arm lines up with mark in dizzy . phase sensor gap is good . just didn't know if the ecu needed a little help
thanks tabetha i can always rely on you for info
Old Dec 28, 2007 | 07:18 PM
GARETH T's Avatar
GARETH T
aslong as its on its timing marks, your all good
one thing to check is the woodruff key in the crank isnt warn allowing your crank pulley to move!
if your not too sure where everything should be pointing
http://www.cannell.co.uk/Manuals.htm
theres a few manuals there you can use
Old Dec 28, 2007 | 08:30 PM
So long as you have used the TDC mark and NOT the ignition mark to time belt up!!
I have seen these timed on the "V" groove, instead of the LUG, nearest the "V" groove which is the TDC mark.
Rsmat
63
Sep 25, 2015 12:11 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
xrmalin
Sep 13, 2015 06:52 PM
Roosie
Aug 15, 2015 08:09 PM
yawiejon
15
Aug 9, 2015 06:36 PM
