multilayer head gasket/long stud
i run a cometic 3 layer gasket just now with no issuesalthough i did first time round with them
doesanyone run/rate the 4 layer cometic?
also i long studded my 200 block with mountune 6
but just incase theres issues with them when i remove head
are arp ones ok to go for stick to mouuntune?
i just remember having 4 arp head bolts to go in place of the standard ones when building engine but was advised against them due to cracking block/head cant remember
any views appreciated
Originally Posted by STUCOS
Col when using 6 long studs,you are ment to use standard used head bolts in the other 4 holes
cheeRS stu
cheeRS stu
surely once they ve been stretched you only get once shot at them no?
saff is working!!!...atm
mine is decked n skimmed and i use a mountune 3 layer steel gasket.....6 long stud all supplied by Ahmed,the 4 other bolts are old used jobbies........
ARP make fasteners/studs/bolts for a living, they don't make rubbish, but it is rubbish to think that a stud is ever going to be strong enough to break a block, if the block were that weak just starting it up would blow it apart with compression.
Idiots who try to force studs, bolts into holes are the likely cause of block cracking, some don't even tap the holes to get congealed oil/crap out before rebuilds.
You use sh bolts in the corners,as they have already stretched,and shouldnt stretch any more,there fore stopping the head from lifting at corners,or so im tld any way
cheeRS stu
cheeRS stu
Mountune one are fine until 450 ATW ish col.
Speak to Alan or Mike if you want something better
Not sure what they are called but they come from Scandanavia somewhere.
Mc5506
Oct 5, 2015 09:57 PM
