WOOHOOOOO and Bugger @ york dragway
Old Oct 10, 2004 | 08:41 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Default WOOHOOOOO and Bugger @ york dragway
the WOOHOOOO bit:
was at york dragway today in the saffy
running 4 greys, T3 ( T4 not repaired yet ) slightly higher comp ratio than STD , and only 17psi cos the turbo is smoking like a good un (wasnt gonna run the car but last one of the year and i had been looking forward to this for months so had to go)
still on standard rims with shyyyyyyyyte dunlop tyres and a complete lack of traction in 1st and 2nd sometimes 3rd depending how hard the change was.
results...............................
in the low 14`s all day untill my last 2 runs.
got a 13.8 @106.55 and was well chuffed.
had 1 last go before i went home,
i manadged a terminal of 108mph on one of the runs
what does your cossie do the quarter in? 2 cossie lads were there and on greens i think and like me couldnt dip below the 14`s.
is it just the crap surface at york?
and
manadged to get a 13.7 @106.79
mate was in his mk2 RS2000 and manadged a time of 15.9 if i remember rightly.
another mate was in his 1600RST and only manadged a 15.4 (previousley manadged a 14.6!!!!!) due to clutch problems.
the BUGGER bit........
on the way down i came onto a left hander sliproad and decided it`d be a good idea to drift round the bend and make lots of smoke off the tyres, i succeded and looked impressive, wasnt till i got to york and noticed the jerrycan and toolbox had smacked the back quarter from inside the boot and totally shafted my rear quarter
dont look bad in the pic but its totally mashed the rear 1/4, only part of the car i wished never to get damadged. bollox, well that`ll teach me for showing off
Old Oct 10, 2004 | 09:38 PM
CosKev3's Avatar
CosKev3
Had my first go today at santa pod
14.9 at 102mph,stg3 greens etc.
How do you get on with gearchanges m8?????
Mine were shit on strip,was gutted missed a gear on all 3 runs
Old Oct 10, 2004 | 09:42 PM
bob s2zvh's Avatar
bob s2zvh
13.6@108mph was my best at crail stg 1 with t34 and 500 cooler! 20 psi of boost!
Old Oct 10, 2004 | 09:52 PM
Kevin Sharp's Avatar
Kevin Sharp
is york elvington? if so i thought the surface was superb for grip.
what power are you running? for those terminals/times id guess at around 300bhp ish with a good launch
Old Oct 10, 2004 | 10:13 PM
chris-m's Avatar
chris-m
kev- york is melbourne dragstrip, not elvington airfield, although its only 10-15mins further away.
the surface is a little "broken up " in places! startline is the only good bit really, times at york though can be good, if its dry and warm. on cold or damp days its generally very poor traction there
rgds
chris m
Old Oct 10, 2004 | 10:16 PM
Kevin Sharp
oh right thanks chris ... sounds like a bit of a dodgy surface like crail then lol
cheers
kev
Cossie Sean
Kev,
its york, NOT elvington!
surface is utter wank.
17psi and greys, guess at 350bhp max?!
non standard internals/head though so who knows, never been power run with the T3 on. (no point PMSL!)
the starts are the bad points to the runs.
heres a few bits of info off my slips:
react: .925
60ft: 2.851
1/8: 8.382
1/4: 14.574 @103.5
react: 1.040 ( )
60ft: 2.699
1/8 9.691
1/4: 14.462 @102.82
react: .945
60ft: 2.614
1/8 9.463
14.107 @ 108.31
react: .990
60ft: 2.598
1/8: 9.418
1/4:14.078 @106.19
react: .942
60ft: 2.406
1/8: 9.176
1/4: 14.056 @ 101.96
react: .836
60ft: 2.459
1/8 9.190
1/4 13.8 @106.55
react: .863
60ft: 2.439
1/8 9.104
1/4 13.756@106.76
not too shabby considering last time i ran i had a .93 T4 and ran between 18sec and 15sec 1/4 PMSL!!! 1st,2nd and 3rd gears were useless!!! from lag to wheelspin city.
its all in the start, need to master that!!!!
Sean.
Old Oct 10, 2004 | 10:21 PM
Kevin Sharp
aye if you can sort the start out you will run much better times but i,d have thought a t3 would have maxed at around 320bhp regardless of the rest of the engine spec?
Old Oct 10, 2004 | 10:24 PM
Danny B's Avatar
Danny B
you really need to learn to drive my car with COSSIE rear suspension on greens standard T3 @22psi boost used to run13.0/12.9 @ 111mph and done this over 15times, 60fts were 2.1's on toyo T1S's
Old Oct 10, 2004 | 10:26 PM
Kevin Sharp
what power you recon on that spec danny boy
Old Oct 10, 2004 | 10:28 PM
Karl's Avatar
Karl
Norris Motorsport
Indeed a T3 even with a 60 trim compressor wheel is no good for anymore than around 320bhp.
Old Oct 10, 2004 | 10:34 PM
Cossie Sean
ahwell, whatever power the tyres let me down big stylee!
wasnt gonna run the car today but when i got there i had to have a go, you know what its like
got sum cut slicks on 17" rims.
was gonna take em but decided not to run due to nackered turbo, wish i had of done now though!!!!!
pretty good times if it couldnt be more than 320bhp........ well chufed!!!!
Seany
Old Oct 10, 2004 | 11:15 PM
dave cos4x4's Avatar
dave cos4x4
Sean, i done a 12.72 last year at york.( 4x4 though )
T34, greens,rs500 type i/c.
you got to do better that next time Sean. .
Dave.
Old Oct 10, 2004 | 11:26 PM
Cossie Sean
i hope so!
next year cossie will be 9.5:1
an even hooooojer turbo and different managment / ALS injector setup.
rear beam/shock/tyre drastic changes.
muchos better times at the pod hopefully.
BRAM
Sep 8, 2015 07:11 AM
Cragrat
Sep 2, 2015 08:25 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
