Best oil for cossie engine?
Old Oct 10, 2004 | 03:43 PM
boXXer's Avatar
boXXer
GASH!
Default Best oil for cossie engine?
Hiya. Whats everyones opinion on the best engine oil to use in a standard/stg1 cossie engine? what weight, make, etc?
Cheers guys,
Mike
Old Oct 10, 2004 | 03:53 PM
The Youth.'s Avatar
The Youth.
cue the opening of a can of worms!!! lol
to be honest m8 there are lots of opinions as to what is best but you won't go to far wrong with mobil 1 motorsport, valvoline synpower and castrol rs 10/50
steve
Old Oct 10, 2004 | 03:54 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
OMG Worms everywhere.
I give it 10 minutes.
Oilman?
Old Oct 10, 2004 | 03:55 PM
CraigN's Avatar
CraigN
i jsut used some of that mobile 1 rally formula 5w50
Old Oct 10, 2004 | 03:59 PM
I have found in the past that the engine when cold is more mechanical sounding with 15w50 mobil 1 motorsport than the thinner oils around, but is much much smoother once warm.
Old Oct 10, 2004 | 04:00 PM
Alps Pacino's Avatar
Alps Pacino
Y2K RS, would that not indicate that it aint doing the engine much good when cold?????
Old Oct 10, 2004 | 04:02 PM
CraigN's Avatar
CraigN
thas why i used 5w50 not 15w50
Old Oct 10, 2004 | 04:21 PM
boXXer's Avatar
boXXer
GASH!
hmmmmm, hope i aint started anything too bad, lol. Same issue when i was asking about my r5 turbo on another site.
Mike
Old Oct 10, 2004 | 04:24 PM
agree with the logic, most people highly recommend the 15w50 motorsport for high hp road cars and race/ rally cars but these will always be brought up to temp before serious abuse
Hard to admit, but all my cosworths in the past 14 years ran on normal good quality mineral oil with regular 5k changes and felt much smoother than when it was swapped for the so called better synthetic oils - these were all standard 2wd cars though.
I used bog standard mineral oil to run in my latest car for the first 2000 miles then swapped to 15w50 mobil 1 motorport and it was quieter when cold on the normal stuff, but within a few mins of use its smoother on the mobil 1.
so I guess its just a case of letting them get up to temp for a few mins before using the loud pedal if you use the thicker synthetics
Also makes a difference if 2wd or 4x4, as the 2wd engine does not have the offset gudgeon pins so are all slappy when cold and the 4x4 with its improved ecu/lambda and knock sensor probably helps to mask the cold running noises to some degree until up to temp.
You also have the problem with the thinner synthetics of noisy tappets and more oil leaks and more oil usage due to the fairly slack tolerances of the cosworth engine as opposed to the modern motors about
Old Oct 10, 2004 | 05:20 PM
Matt @ CAE's Avatar
Matt @ CAE
Old Oct 10, 2004 | 05:32 PM
mk3cosworth's Avatar
mk3cosworth
castrol rs 10/60 what i use
POPEYE's Avatar
POPEYE
FAIRY CAKE
i use the valvoline 5/50
works for me,but then mine has a complete 4wd engine
Old Oct 10, 2004 | 06:11 PM
dave green's Avatar
dave green
castrol RS10/60. what i use
Old Oct 10, 2004 | 07:31 PM
markcoznottz's Avatar
markcoznottz
Didnt later 2wd engines have offset gudgeon pins before the 4wd engine came along?. I found old road test of 1990 4x4 saph, and ford recommended synthetic oil only for this engine, so must hav used mineral in the 2wd engines.
Old Oct 10, 2004 | 07:43 PM
Moose 130's Avatar
Moose 130
Silkolene Pro S 10w-50 was recomended by Oilman to me.
price is pretty good too for 25 liters.
Old Oct 11, 2004 | 12:43 PM
oilman's Avatar
oilman
Oilman recommends:
10w-50 as being a good viscosity for cossie engines and 15w-50 as an option but not so good for cold start protection in winter.
As I've stated before, sae 60 is really too thick.
Have a look at tech data here: http://www.opieoils.co.uk/lubricants.htm
Where's the oil thread?
Simon
Oh no not another oil thread
Old Oct 11, 2004 | 12:47 PM
R4N SS's Avatar
R4N SS
i use castrol rs 10w/60 - is that any good?
Old Oct 11, 2004 | 12:56 PM
Rene's Avatar
Rene
i use the same golden stuff
Old Oct 11, 2004 | 01:13 PM
oilman's Avatar
oilman
If you're asking whether it's a true synthetic or a hydrocracked oil then the answer is it's a hydrocracked.
Does it protect better than a true synthetic - No.
Just make sure you change it regularly would be my advice as it will not stay in grade for too long. (It will be a 10w-40 within a couple of thousand miles)
Simon
Old Oct 11, 2004 | 01:46 PM
Jimmermac's Avatar
Jimmermac
site wrecker
im on castrol 10w60
Old Oct 11, 2004 | 10:39 PM
boXXer's Avatar
boXXer
GASH!
hmmmm, 10-60 seems to be the one. i ran it in my mk1 escort, and it did the trick then.
Mike
Old Oct 12, 2004 | 08:55 AM
oilman's Avatar
oilman
It's personal choice really but I think it's too thick really.
Simon
Old Oct 12, 2004 | 09:03 AM
JAP CRAP's Avatar
JAP CRAP
you got a website oilman?? with prices on?
now I got a big wing sump it costs twice as much to do a change
Old Oct 12, 2004 | 09:09 AM
oilman's Avatar
oilman
Yes. http://www.opieoils.co.uk/lubricants.htm
For prices, just drop me an email sales@opieoils,co.uk
Simon
Old Oct 12, 2004 | 03:42 PM
Ginge !'s Avatar
Ginge !
just finding my feet
dont worry ya not alone there
RUBY123
Oct 22, 2023 12:04 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
