General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
got a phone call earlier from the company balancing my bottom end, they said they need the crank pulley? my mate has said i dont use the 2.0 mondeo one in a zetec turbo? any ideas? cheers
depends on the alternater , or if u need a cps crank pully side? is so then a 1800cvh one if not a zetec one or if ur gona use all cvh shit like alternater then a cvh one , its just so its all ballaced to each other
Cant use a CVH one as the Zetec water pump runs off the same V groove pulley which you need off a 1.8 Escort or Fiesta Zetec (The mondeo pulleys are different)
You need a 1.8 Zetec pulley mate, iam sure, though ill check anyways.
